Home > Maintenance & Mods (L322) > Aero Front Windshield Wipers Fitted
Page 9 of 13 <123 ... 8910 111213>
Arkle
The Conti wipers I bought have lasted just over two years.
They still wipe ok, but the drivers side rubber is splitting near the RH bottom edge.
So, I have just bought another set.
A small price to pay not to have to put up with the annoying clunk and the wipers work very well indeed.
http://www.ebay.co.uk/itm/231202190017?clk...rmvSB=true
Post #438541 15th May 2017 10:51pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Old thread, but “Continental Direct” have no connection with Continental the German tyre etc. manufacturer (whose IP department they have surely come to the attention of) - they just source and brand cheap parts from elsewhere. Believe these wipers are made by Bremen.
Post #462263 26th Dec 2017 11:19pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Aero wipers( beware)
Just a warning when fitting the Aero blades keep hold of the plastic bits that have to be removed when fitting.
I fitted Aero blades 6-8 months ago and have both failed, They have not been used with ice on the screen, and without warning they both failed at the same time, that was on the weekend so no chance to get some new ones off the shelf, Had to wait until Monday and go to my local LR spend £4:60 each for plastic clips to be able to go back to the old style blades off the shelf.
I could not wait for some to be sent by post as I needed the car with all this snow about so keep the plastic bits in the car?
Post #470157 26th Feb 2018 2:59pm
bob-lad
Or put a spare set of aero blades in the boot?
Post #471255 5th Mar 2018 10:26pm
longmanh
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Are these the correct ones: https://www.ebay.co.uk/itm/AERO-FLAT-Front...xyCGNTMFw~
Post #472046 10th Mar 2018 9:08pm
Clabs
Longman
I bought those and they work really well. The rear one they supply is just a standard one.
Post #472062 10th Mar 2018 10:30pm
longmanh
Brilliant, thanks mate
Post #472063 10th Mar 2018 11:06pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Latest concencus is
Contis from Boltonbits
Or
Advance factors new ones,
Or any others ?
My Aeros are starting to split so,want to get a new set before they fail
Thanks J
Post #472592 14th Mar 2018 4:50pm
Gold Ranger
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
https://www.ebay.co.uk/itm/HQ-Windscreen-W...1438.l2649
these are a bit cheaper at £18.85
Post #472597 14th Mar 2018 5:15pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
I've tried the Boltonbits and HQ blades from ebay. Both have been great to begin with but started knocking after a few months. Currently on three month old HQ ones and so far so good. Haven't tried the AF (site sponsor) ones as they were out of stock previously. They're currently in stock for £17.71 plus £4.95 postage.
I also checked my angle of dangle (thanks to Stan for the image of a protractor which I cut to 86 degrees following suggestion from Craig). Looks spot on so that doesn't look like the cause of the previous thump. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #472603 14th Mar 2018 6:16pm
bruno22rf
England 2004 Range Rover Vogue 4.4 V8 Java Black
Bought a set from one of the suppliers mentioned and one blade simply failed to clear the screen - near side one only wiped about half it's length. Had to buy Bosh one in the end but on fitting the Aero's both clips disintegrated so bit of a disaster really Sad
Post #472607 14th Mar 2018 6:26pm
Deltaevo
United Kingdom 2002 Range Rover HSE 4.4 V8 Alveston Red
I bought some Aero's last year, during the recent icy spell one of mine shredded. Got a pair of replacements from my local screwfix for 12 quid the pair, slight faff with the fitment but all's well.
Post #473277 21st Mar 2018 9:35am
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
When I removed the original standard wiper blades to fit a pair of the newer flat 'aero' blades, both original blade clips broke apart. they were very brittle.
I find the newer flat 'aero' blades don't last very long, I've got through two sets in a year. So, if I wanted to re-install some standard wiper blades are these the complete replacement clips set I need please?
https://www.ebay.co.uk/itm/RANGE-ROVER-L32...Sw-3FZCN7~
Post #473380 22nd Mar 2018 2:18am
they look like the ones....you could ask dan at duckworths for a price and you will know that you'll get the proper ones. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #473390 22nd Mar 2018 9:02am
Tinman
That's right these are the same but no cheaper ask Dan and you won't pay postage?
Post #473397 22nd Mar 2018 9:54am
