Home > Technical (L322) > 2003 TD6 refuses to idle
lesmcm
South Africa 2003 Range Rover HSE Td6 Atacama Sand
My 2003 TD6 has suddenly started to refuse to idle. It runs OK at just over 1k revs but let it run at normal tickover it stops within a few seconds. The fuel pressure checks OK on a Hawkeye, it only drops after the engine stops. The injectors were serviced about 3 months ago the HP pump pressure release valve O rings were replaced at the same time and a new intermediate fuel pump has been fitted. After the engine has stopped I have to press the accelerator to the floor to restart it. Then I get a repeat of the engine stopping again. Any info or suggestions will be very welcome. Incidently no fault codes are shown.
Post #439025 20th May 2017 1:30pm
