Home > Maintenance & Mods (L322) > High Beam Mod |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
How did it turn out? |
9th Jun 2017 10:19pm |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
Looks gr8.. will post a pic when I'm out..
9th Jun 2017 10:30pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 688 |
Where did you get them?? 2007 VOGUE SE 3.6 TDV8 |
10th Jun 2017 11:32am |
Got them from fleBay mate..
10th Jun 2017 12:12pm |
Thank you 2007 VOGUE SE 3.6 TDV8 |
10th Jun 2017 2:07pm |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 |
Interested in what they perform like Regards
10th Jun 2017 7:13pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
How can they be 80W per lamp when the quoted running current is a maximum of 670mA. More like 8W per lamp.
10th Jun 2017 8:17pm |
TOF Member Since: 13 Mar 2013 Location: Gloucestershire Posts: 53 |
Are there any error lights on the dash from fitting these... |
10th Jun 2017 8:50pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
My thoughts exactly , everything I have tried runs with a cooling fan because of the heat generated and that is before I believe the fantasy outputs quoted, I'm now trying some with a great big bunch of braided tails to dissipate the heat to keep the noise down of four or six cooled lamps running. 2008 MY Supercharged Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
11th Jun 2017 2:27am |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
Most of these aftermarket bulb are not E stamped, they can look good and they can be more effective then normal bulbs however if you have an accident this is a quick way of blaming you for the accident or voiding the insurance for non compliant parts being fitted |
11th Jun 2017 9:53am |
Clive603 Member Since: 21 Jun 2016 Location: Sussex Posts: 35 |
Lumens are the unit for visible light output, watts for input power. Typically approaching 5 times as many lumens per watt from LED as from halogen so a LED drawing 8 watts from 12 V should be roughly equivalent to a 40 Watt halogen.
11th Jun 2017 1:35pm |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
i have thought about these myself few times, anyone know if they are error free on pre 2005 range rovers. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
11th Jun 2017 5:04pm |
Don't worry about sorting the bulbs out for error free, just turn of bulb check in LCM I'm sure if a high beam bulb is out you would notice it |
11th Jun 2017 10:42pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
80W per light would also be illegal for road use in UK |
12th Jun 2017 11:15am |
