Home > Maintenance & Mods (L322) > Air Conditioning compressor relay
Ollie7195
England 2005 Range Rover Vogue Td6 Barolo Black
Hi all,
Trying to sort out the problem with my A/C pump, the light on the dash comes on, the belt to the clutch is spinning with the outer pulley, but the clutch is not engaging, I have 5 Bar of pressure in the system (seems to be normal) and have measured the coil on the compressor and its ~4 ohms (again seems to be normal) the voltage to the pump is only 9.2 volts andddd......its like that all the time regardless of a/c on or off or even without keys in the ignition!
is there a relay somewhere thats possibly failed? I have looked for wiring diagrams but not found anything
Its a 2005 TD6
Post #439343 23rd May 2017 4:44pm
