Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005 |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Probably in a different position on the diesel ?
31st Jan 2017 9:34pm |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 519 |
The BMW 740d stat is an 88 deg version of the stat that fits the M62 engine, just doesn't have the heater, otherwise it's a straight swap with no need to mod anything which is what I wanted. Anyway I took the induction pipe off as well as the engine cover, still managed to damage myself. Mind you I usually do when I have a spanner in my hand. Drives:
31st Jan 2017 10:07pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7905 |
Skin heals... at least your engine will love you for it...!! Pete
1st Feb 2017 12:14am |
This is very true
1st Feb 2017 11:51am |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 |
After trying in vain to find a cheaper alternative to the conversation kit the dollar/pound exchange rate improved and I ordered mine. I was also concerned that the higher temp was a positive design and shouldn't be messed with. After lots of reading I am convinced it will not do anything negative including decreased fuel mileage. I have a pin hole radiator leak that I was going to fix at the same time I changed the thermostat but I am curious to see if the drop in pressure will have any affect on the rate of leak. |
29th Mar 2017 2:59am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
The change from a 200kPa cap to a 140kPa cap certainly reduced my coolant loss. I still haven't got around to fitting the new radiator I bought before Christmas. Ron B. VK2OTC
29th Mar 2017 4:26am |
Waynetab Member Since: 19 Jul 2015 Location: Rochdale, Lancashire Posts: 132 |
My IID tool brings up this fault code. Does this mean I have the lower temperature stat? Not Galway but Balmoral green actually 148,000 miles |
30th Mar 2017 1:43pm |
Not necessarily. You could have a faulty circuit/thermostat. Have you visually inspected the connection? |
30th Mar 2017 3:38pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 816 |
I agree with the Doc, it's either you do have the mod or you have a faulty circuit within the 'proper' thermostat.
30th Mar 2017 3:59pm |
RAVE says the thermostat heating element is triggered under load. Does this mean when you accelerate quickly? If so then maybe that circuit could be used to trigger a warning light such as flashing $$$ or £££!. Maybe a recording of sirens or McLaren P1? |
30th Mar 2017 5:51pm |
Will have a closer look tomorrow, thanks Not Galway but Balmoral green actually 148,000 miles |
30th Mar 2017 7:13pm |
I did the kit today. One thing to mention at least for me is that allen bolt head use. Although the. Standard head bolt will go on 99% of the way there is a bolt head off the block that makes getting that last 1% tightening impossible with the 1/4 drive 10mm socket. The Allen head was a must for me to get it tight enough. |
24th May 2017 7:19pm |
That's interesting... mine was fine with the four normal bolts, mind you I did use a thin wall deep 10mm socket so maybe that's the difference.... Pete
27th May 2017 11:18am |
Yes I'm sure socket wall thickness is the key. The 1/4 inch drive socket is smaller than the 3/8 but mine was just not enough. |
28th May 2017 1:57am |
