Home > Maintenance & Mods (L322) > Help needed with RANGE ROVER SCL / ESL / ELV EMULATOR |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
the EWS ECU is for the immobiliser chip in key, it can be found driver side next to the gear lever, maybe find a pin out diagram some where for the correct one |
26th May 2017 1:29pm |
smiler289 Member Since: 11 May 2016 Location: matlock Posts: 124 |
Hi. Thanks I thought it was around that area. A white box isn't it? Presume I will have to take all the trim apart around the gearstick to see it?
26th May 2017 1:39pm |
26th May 2017 1:54pm |
Do you think by them saying "P/N signal wired through esl.. ." They mean park /neutral? |
26th May 2017 2:04pm |
yes white box, you need to remove the cubby hole, down to the gear lever leather, it's a white box drivers side, loosen the 1 bolt you can see, you can then lift it out without fully removing the bolt, from memory you lift it and pull it towards back of the car
26th May 2017 3:06pm |
Contacted the seller. Asked them if they could tell me which wire I am looking for and does p/N stand for park/neutral.
26th May 2017 5:21pm |
26th May 2017 6:59pm |
I will have to stop at this point as I can't be certain and would hate for you to.follow my advise then brake something further
27th May 2017 5:54pm |
No it's a v8. Something just doesn't add up with what information I have been given. Maybe something has been lost in translation. |
27th May 2017 5:57pm |
AusRR Member Since: 27 Jan 2017 Location: Sydney Posts: 7 |
Hey Smiler, did you have any success with the emulator? |
25th Jun 2017 4:05am |
Hi. No I haven't. The emulator will let me turn the key everytime but not start the car. I have had the car into a land rover specialist recently, infact they had it for two weeks because it had so many faults that needed repairing and its got to go back for the air conditioning because the regassed it but must of not tested it because it doesn't blow cold. Fuel gauge doesn't go all the way to the top either but I can live with that for now.
25th Jun 2017 9:20am |
Im having the same issue as you smiler, I emailed them about running 12v to ews to esl and got the following response:
25th Jun 2017 10:10am |
"Make sure that + 12V power supply properly, already with key in ON position on dash.
25th Jun 2017 10:41am |
ParabolD Member Since: 16 Oct 2017 Location: Plzen Posts: 1 |
Hello guys. Did you figure out the emulator? My is on the way, so I want just to be ready...Thank you. |
16th Oct 2017 10:57am |
