Home > Technical (L322) > 3.6 fuel leak at filter
rar110
I've just experienced a big fuel leak at the top of the filter housing. It looks like one of the clips holding a fuel line has failed. Part number WJP501400. See diagram below. Anyone else had this? Should I replace all four hoses?
Thanks
 ______________________________
Post #445253 21st Jul 2017 11:59am
sako243
Are you sure the clip has failed? I had a similar one and the pipe hadn't been pushed on properly. Required a significant push to get it to latch properly.
Just may not have been pushed on properly if it's been recently changed. Ed
Post #445266 21st Jul 2017 1:29pm
rar110
Thanks for the suggestion Ed. But I'm certain it's broken. The blue button on one side has broken off. The connector disconnects from the filter housing by depressing the bottons on each side of the connector. As button is broken there's no resistance and it compresses on one side. Here's a pic of the missing/broken button.
Post #445268 21st Jul 2017 1:41pm
sako243
If they're easy to source (rather than having to ship from the UK) I'd just replace the one but keep an eye on the others. If they're not moved they shouldn't self disintegrate.
However if you're going to be stumped for shipping it may be worth getting all of them just in case. After all they're (hopefully) all the same age so in a similar condition. Ed
Post #445269 21st Jul 2017 1:46pm
rar110
Thanks again. I suspect some of the hoses might have been replaced as the hose is darker. I'll have a closer look tomorrow in the daytime. Here another pic of the housing. Sorry if it seems I'm drip feeding pics.
Post #445270 21st Jul 2017 1:50pm
sako243
No worries, I'm bored waiting for some numpties to balance a set of supposedly unbalanceable wheels (BFG KM/2s). Funny thing is if I'd been in Wales the local garage with a good old fashioned level based one would have done it by now...
Looks like 4 are older? One of them being the one that's leaking. Ed
Post #445272 21st Jul 2017 1:53pm
rar110
Yep I think I will replace the lot.
Thanks, Pete ______________________________
Post #445273 21st Jul 2017 2:00pm
rar110
The online parts diagram indicate this pipe is the supply pipe for the fuel fired air heater. Can anyone confirm this?
If so it should be low pressure right?
Thanks ______________________________
Post #445307 22nd Jul 2017 1:51am
rar110
My interim solution as no parts in Australia. Fuel injector hose and hose clamps.
Post #445309 22nd Jul 2017 3:53am
sako243
Everything on the fuel filter side should be low pressure (high pressure side in this engine is 23,900PSI so rubber hoses, I don't think so Whistle ). They're all the metal pipes running along by the injectors. Ed
Post #445324 22nd Jul 2017 9:43am
rar110
Thanks Ed, that's reassuring as we are doing a day trip tomorrow. I was hoping this would be on a return line. So true low pressure. ______________________________
Post #445328 22nd Jul 2017 11:10am
rar110
The 160km round trip happened without any leaks. Very happy. All good until the parts arrive. Replacing all four hoses. ______________________________
Post #445432 23rd Jul 2017 8:06am
Can't beat jubly clips!!
Always have a few spares knocking around, you never know what you might need them for, have repaired quite a few non hose related problems with jubilee clips too😁 There is nothing that can't be fixed with a hammer😜😜
Post #445457 23rd Jul 2017 10:22am
rar110
I agree. But don't bother with the el cheapo ones. A frustrating waste of time. ______________________________
Post #445459 23rd Jul 2017 10:27am
