Home > Technical (L322) > Passenger and Rear Air not cold
S.Hill
United States 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
I have an 08 RR SC, the drivers side is blowing cold and hot but the passenger side goes from cool, )probably 15 or so degrees warmer than the drivers side) to hot. Ive seen where the passenger blend motor is a known issue, but wasn't 100% sure this was what I was experiencing.
I picked up the blend door motor from Rover Land Parts
http://www.roverlandparts.com/2003-2012-RR...motor.aspx
but was a little confused when it came with 3 motors... not sure if I have 3 of the f'ers to find and replace or just the one.
Also downloaded the 3000+ page workshop manual - but it is a little frustrating finding the right place to start...
So... if it is the passenger blend motor, is there a diagram where to find/replace it? And if not any help would be much appreciated.
Thanks,
Shawn
Post #445722 25th Jul 2017 4:13pm
S.Hill
Turns out it wasn't a blend motor but way low on freon... I wouldn't have thought that would make a difference in the side to side temp control but it does.
Post #445833 26th Jul 2017 2:19pm
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
I've been told that if you don't use the a/c regularly the freon can gradually leak out..... QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #445881 26th Jul 2017 9:03pm
