Home > Technical (L322) > Font knocking/clunking over bumps. L322 TD6 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Start with your ARB drop links.
25th Jul 2017 10:46am |
phillips321 Member Since: 05 Nov 2016 Location: Countryside Posts: 50 |
Ok the the ARB drop links are a little loose where they connect to the ARB. How tight do these need to be? Is it a case of just tightening them up or worth replacing the whole bar and bushes? Any idea on parts numbers and where I can source a pair?
26th Jul 2017 9:06am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Parts for the L322 are readily available, there are a lot of specialists who provide some excellent savings over mainstream parts providers....
26th Jul 2017 11:48am |
there my lack of mechanic knowledge causing trouble. The bits that are warn are the rubbers on the end of the drop links. I've just googled and it seems the come connected to the bar for less than £25 a pair. Might as well just replace the whole piece for that price. Here's to hoping it fixes the knocking!
26th Jul 2017 11:53am |
Now i'm going to ask, is it better to have jacked the car up to do this or have it on the floor? |
26th Jul 2017 12:03pm |
As with all suspension jobs it's better to tighten up with it under load...ie, all 4 wheels supporting the car.... this however isn't the most practical way of changing the drop links, I usually try to jack the wheel as close to the wheel.... sometimes this isn't easy and it is better to lift the car an place an axle stand under, remove the wheel and then jack up the suspension so that it just lifts the car off the axle stand, but only by a millimeter!! just incase!
26th Jul 2017 12:49pm |
When the car is on a flat level surface the drop links aren't under tension or compression so can just be unbolted with the wheels on the ground.
26th Jul 2017 4:49pm |
Most have had trouble with third party drop links. May be better to go with LR parts from dan@duckworths. .
26th Jul 2017 5:29pm |
The LR ones are Lemforder at least the ones I got from Dan were a while back. There is nothing that can't be fixed with a hammer😜😜
26th Jul 2017 5:45pm |
Don't forget that the washer is a spacer.... otherwise you'll be doing the same job again in the near future Yesterday I couldn't spell Engineer... Today I are one!
27th Jul 2017 11:15am |
