Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
Lots of owners on here will be watching with interest, thinking , is it a job I can do, when needs arise.
11th Mar 2017 10:26am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7629 |
The specialist I used just kept flushing it out, I imagine with some chemical... took about 4 flushes.... I ran it for a year, with a slight shine on top of the antifreeze when looking in the header tank. Just had big service so had it changed again now, just for my peace of mind....
11th Mar 2017 12:00pm |
Oil in coolant?.... easy to spot....
11th Mar 2017 12:05pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Chaps does this pipe feed the turbo?
20th Aug 2017 10:01am |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 895 |
Yes, it connects the oil cooler in the rear-centre of the V to both turbos |
20th Aug 2017 10:21am |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 183 |
Has anyone attempted a warranty claim for this? My LR warranty is about to expire and I have been on at LR for a year now regarding the (relatively small) oil leak caused by this.
18th Dec 2017 1:32pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 |
I would check the small print on your warranty, I’m sure that I’ve seen oil leaks on a list of exclusions and I don’t think that I’ve seen anything other than a JLR warranty recently.
18th Dec 2017 3:18pm |
carpcat Member Since: 13 Oct 2017 Location: Surrey Posts: 58 |
Just found the oil leaking from mine with the oil burning smell (and smokey haze around the lights last night after a drive). Can I assume you don’t need to drain the oil to pull off the union and replace the O rings? Ordered the viton rings from EBay. If this fixes it I’ll be a happy chappy Chris |
21st Dec 2017 2:38pm |
Correct, no need to drain the oil to replace the O rings.
22nd Dec 2017 11:28am |
Thanks Mike. The coolant tank looks like there’s darker deposits on the side, but I wouldn’t say the coolant itself is dark with oil if that makes sense. I certainly haven’t got a thick slick on top. To be honest the coolant probably needs changing anyway. I’ll keep an eye on it after changing the o rings. Was yours still leaking in the same place after the o ring change or was it the oil in coolant that made you change the cooler? Do you mind me asking what the price of the cooler was from Dan? Chris |
22nd Dec 2017 12:43pm |
Just checked mine, took the pollen filter housing out and the cover off, all looks fine.
22nd Dec 2017 6:58pm |
There are two problems that can cause the oil to run down the bell housing, one is the turbo feed O rings, the other is a failure in the oil cooler.
23rd Dec 2017 11:22am |
OK, so changed the o rings the other day, but with the engine cover off could see the engine oil was accumulating on the top of the oil cooler assembly, so it’s either the oil cooler or gasket at fault. Ordered the gaskets to replace as the cheaper option first. Is there anything I need to be aware of when changing no this? Simple as stripping the top components away to get to the cooler? Do I need to drain oil or coolant to complete this? I’ve also read about cleaning the sensors at the same time. Chris |
28th Dec 2017 1:14pm |
Sorry can't answer your question(s) but if you can post up some photos of this job once you're done it would be a great Chris.
28th Dec 2017 2:04pm |
