Home > Maintenance & Mods (L322) > Ignition problem |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3192 |
Looks like your switch is on the way out. Repacement switch is approx £99 IIRC. Do a search on "igntion switch" Best replace it before it packs in completely . As I know to my cost. John
4th Sep 2017 10:24am |
Mart67 Member Since: 26 Apr 2016 Location: West midlands Posts: 45 |
All sorted, £48 from Duckworths!! |
14th Sep 2017 8:21am |
standupking36 Member Since: 30 Jun 2017 Location: lincolnshire Posts: 76 |
was it easy to replace? |
14th Sep 2017 9:01pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
It's not hard, no special tools required, just download Rave from the WIKI, take your time and take pictures as you go.. Pete
15th Sep 2017 4:59pm |
did it come made to your key? or do you get a new blade? |
17th Sep 2017 8:15pm |
The switch is separate to the ignition barrel, it's the switch below the barrel that fails so you keep your old key.... Pete
17th Sep 2017 9:21pm |
oh ok pete thanks, so with it being notchy, its not actually the key part?? |
17th Sep 2017 9:28pm |
Easy change, 1hr max, all you need is a set of torx bits. I only changed the actual switch side of the barrel not the barrel itself. |
21st Sep 2017 2:55am |
