Home > Technical (L322) > Rear brakes/Vibration |
Do the hand brake adjustment procedure it's in the WM something to do with holding the handbrake switch up. There is nothing that can't be fixed with a hammer😜😜
9th Sep 2017 8:35pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
If the epb isnt holding you will need to manually adjust it before doing the reset procedure from the WM. Basicallly you move the cog till you cant move the wheel anymore then back it of about 3 clicks then do the reset procedure. Theres an excellent guide here for brakes although for a disco 3 same type of system and work involved. Hope its ok to the post the link to a sister site but i found this very useful.
10th Sep 2017 4:21am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 761 |
My passenger seat vibrates too
10th Sep 2017 8:15am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7905 |
Hub bushes won't cause a vibration that bad
10th Sep 2017 12:15pm |
