Home > Technical (L322) > handbrake Q |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7905 |
Probably the automatic adjusters, they let them off to fit the disc then pulling the handbrake should wind them in but I doubt yours will be, they seize up.... Could also be a rusty backplate, the shoes fix to the backplate and these rust out and allow the shoes to move instead of pressing inside the disc....
11th Sep 2017 10:36pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 799 |
I reckon that's whats happened pal , the running gear is in really good condition , no real corrosion of any sort , I had the ruddy wheels off earlier to do the height sensors ! doh ! have these got the hole to adjust them threw ?? |
11th Sep 2017 10:43pm |
I can't remember, should say in RAVE which you can download from the WIKI...
11th Sep 2017 10:50pm |
ha ha , ok pal , I use mine as I leave work , just to shut the gates behind me |
12th Sep 2017 9:38pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
there is an adjustment hole |
13th Sep 2017 1:07pm |
cool , that's what I was hoping pal |
13th Sep 2017 9:59pm |
