Home > Technical (L322) > water |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
I'll be following the timing chain job if you keep posting about it.
16th Sep 2017 10:33am |
I looked at RAVE. It might be worth dropping the lower sump cover to see it there is any plastic chain guide in there. Perhaps when I do the next oil change. Ron B. VK2OTC
16th Sep 2017 10:48am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 698 |
From what I can see and I am properly wrong but the earlier housing and thermostat which was fitted to the earlier models, the thermostat was 10mm shorter, if this is correct, then it would be no good.
17th Sep 2017 1:26pm |
This is a quote from this thread: http://www.fullfatrr.com/forum/topic39362.html
Ron B. VK2OTC 2004 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
17th Sep 2017 1:32pm |
yes, thanks, i have seen that post befor
17th Sep 2017 2:07pm |
17th Sep 2017 2:08pm |
OK i got the thread now RR 2005 4.4 petrol
17th Sep 2017 2:13pm |
yes that looks like the way to go
17th Sep 2017 2:26pm |
Removed the crankshaft boss to day
23rd Sep 2017 1:14pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
https://www.germanautosolutions.com/diy_te...ls_diy.php
24th Sep 2017 8:05am |
thanks for the links
24th Sep 2017 11:15am |
That's not the type i used, mine was like the ones off ebay, about £120, i had an old laptop out in the garage with me but no internet connection unfortunately.
24th Sep 2017 3:43pm |
yes, they look like the ones i have ordered
25th Sep 2017 12:40am |
I replaced all 3 chains although none of mine showed any wear really at 110k miles and I replaced the cam chain guides as well as all the timing chain guides of course but even the timing chain guides looked fine but mine has never been on lpg which is my theory that the higher engine temps makes the guides brittle.
25th Sep 2017 1:00am |
