Home > Technical (L322) > Smoke after idle.
TamHare
Scotland 2005 Range Rover Vogue Td6 Monte Carlo Blue
Smoke after idle.
They 2005 td6 has a smoking problem.
If I sit in the car with it idling for say 15mins when a go to drive away I get plooms of white smoke For 300 meters then it clears. The same hapend when stuck in road works for 15mins. The car stats no problem with no smoke and drives fine with no smoke it's only when I pull away after a longish idle time.
Any ideas? I asked a mate and he said it's the bmw td6 and that they all do it and there is nothing that can be done. Please tell me it's not so.
Thanks
Post #451272 18th Sep 2017 12:38pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
id say turbo seals are getting week with the smoke being white , I had a turbo petrol car that only smoked at idle , the turbo was at fault , my td6 does smoke at really , no more than a derv should so I don't know what your mates on about ??
Post #451284 18th Sep 2017 1:47pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
I sat in the car last week with the csr idling.
I was running the iid tool, but a bit longer than I normally do.
Taking the car after for a run, she smoked on acceleration.
No problems since. Must be a diesel thing. Thumbs Up
Post #451318 18th Sep 2017 7:45pm
Videoman1959
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Nearly the same prob..
If I start my car after about 5 mins I smell a burning smell and white smoke escapes from under the car. The has happened intermittently, three times is three days.... not at all yesterday . Any ideas please? 'Knowledge Is Power'
Post #451692 22nd Sep 2017 6:04am
gregdav
If the temperature has been 8 deg or below, it will be the fuel burner heater starting up.
The exhaust for it is underneath, near side more or less in line with the front door.
The actual unit sits right below the battery. Thumbs Up
Post #451693 22nd Sep 2017 6:11am
Videoman1959
I doubt it in this instance as this was a midmorning start-up. But thank you for the info. The burning smell was quite noxious really. My wife said 'are we burning petrol' ? 'Knowledge Is Power'
Post #451695 22nd Sep 2017 6:21am
gregdav
If the ambient air temperature is around 8 deg or below, and the water temp is below 65 deg or there abouts, then the fbh will kick in.
This happens on mine, especially if you are doing short journey's.
Listen for a clicking coming from rear of car.
Very common on the td6.
Greg.
Post #451696 22nd Sep 2017 6:42am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
White smoke is unburnt fuel. Could be a faulty injector. Have you fitted the modified cc breather or at least changed the old filter element, if not I would do that first. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #451697 22nd Sep 2017 6:47am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Totally agree that after a long idle it will smoke a bit when moving off, but not much and only really noticeable at night. I always try to mix driving styles to make sure the system gets a bit of a clear out every few days. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #451711 22nd Sep 2017 11:26am
Mikey
Its a faulty injector/s, or blocked crank breather. Both fairly common on higher mileage cars Thumbs Up
Post #451720 22nd Sep 2017 12:37pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
I had exactly the same problem on a freelander, always believed it to be an injector but never actually investigated further.
Post #451724 22nd Sep 2017 1:07pm
TamHare
Thanks everyone for the input.
It is quite a high mileage td6 so expecting a little smoke but not as much as I'm getting.
This morning I got lost of power and would not rev over 3k found split in upper turbo hose so order one. Hopping this will fix the power issue. And I'll investigating the smoke on next service for now I'll just not sit with car turning over when the wife's in asda
Post #451763 22nd Sep 2017 6:29pm
bembo449
split hoses can cause all sorts of issues on derv engines so don't be surprised if you've inadvertently fixed your smoke issue aswell pal lol
Post #451797 23rd Sep 2017 8:48am
