Home > Technical (L322) > Engine fault |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Can be all sorts tbh.. vacuum leaks, Pcv system,bad maf sensor ect. Start with the obvious like the Pcv hoses. General inspection on them and maybe a smoke test to find any leaks |
18th Sep 2017 7:11pm |
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Ford Hill, Wirral. Not Merseyside Posts: 554 |
All hoses seem good. My son is a mechanic and he's checked, but I just thought there might be something obvious! Don't think it's the MAF as it is only registering the fault on one side and the MAF is a single intake into the SC. Thinking perhaps Lambda sensor???? Tony
18th Sep 2017 7:26pm |
Could be a sensor but knowing a rangey it could be a multitude of things..if you have done a smoke test and tested the fuel trims /fuel pressure/ fuel filters good and alls well then a sensor would be next on my list.. |
18th Sep 2017 7:53pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 799 |
thought IId was as good as dealer level so would pinpoint the fault ?? |
18th Sep 2017 8:06pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
did you ever sort this? sounds similar to mine Current stable:
22nd Jul 2019 2:22pm |
Yes. All sorted. Lambda sensor. 5 minute job to sort. (well for my lad that is) Tony
22nd Jul 2019 3:10pm |
maye not the same as me ten as my voltages look about right cheers Current stable:
22nd Jul 2019 3:11pm |
I didn't check voltages to be honest, but I had a new battery fitted in March. Tony
22nd Jul 2019 3:14pm |
