Home > General > What Did You Do In Your Full Fat Today
Page 257 of 370 <123 ... 256257258 ... 368369370>
fisha
RR207 ...
Think of it like a defender ... it aint a defender if it aint got dents in it. . .
I'll get me coat. V8 or else ...
Post #453269 7th Oct 2017 3:48pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Fitted a fullfatrr.com sticker to the new TDV8
(null) by -jamieholmes@btopenworld.com-
Post #453285 7th Oct 2017 6:54pm
AMD
Drove the bride and groom from the church to the reception in style...
 Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #453345 8th Oct 2017 11:28am
steeplejack
Wales
No more noise
I got the air-con regassed after reading a few posts in the forum suggesting that the irritating noise I could hear when the air con was on, which varied with the engine revs, could be caused by low gas pressure. Result Exclamation Noise gone and I am now back to silent running as it was when I bought it last year. With the added bonus of it being properly cold again, just in time for winter. Rolling Eyes Just pleased it's not a new compressor or fiddly tensioner replacement job.
I also fitted the new coolant expansion tank as I was starting to get spurious coolant low messages. Nice easy job, thanks to Cam-tech Craig for pointing out the obvious fix. Bow down
I also got some prices for sorting out my rear arches.... Big Cry Exclamation Exclamation
Post #453771 11th Oct 2017 8:37pm
Weegie
Fitted Varta 020 battery. Tight squeeze but got there. Thumbs Up John
GAP iiD BT
Post #453839 12th Oct 2017 4:38pm
Gumball3000
United Kingdom 2011 Range Rover Vogue SE TDV8 Zermatt Silver
Bought another one . Thumbs Up Thumbs Up
Post #453847 12th Oct 2017 6:21pm
buffalo4
2009 Range Rover Vogue SE TDV8 Bournville
Gumball V.Nice Thumbs Up
Post #453861 12th Oct 2017 7:51pm
Gumball3000
Thanks m8 , I liked the old girl that much i thought why not.
Post #453869 12th Oct 2017 8:40pm
gizze
Re: No more noise
Remember it is also a dehumidifier and will keep your cabin condensation free.
Plus, never turn off the climate, you will dry out the seals and that can start to get expensive.
Also, hate to say this, if you have lost the gas it has escaped from somewhere, did you get an aircon company to test it before getting a refill?
Quite often the seal at the fill point that fails, which is a £5 part.
If you find it is making a noise again in a couple of weeks get a local specialist out. Porsche 911 (996)
2015 BMW 5 Series Touring
Not got a LR of any kind at the mo, and got itchy feet.
Post #454059 14th Oct 2017 8:58pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Drove to dat der lundun and back with only one ' water in fuel' message which I cleared. ( See maintenance/ mods section ). Have ordered replacement sensor now to see if that stops the problem message. Trip showed average of 32 mpg for 420 trip.
Post #454104 15th Oct 2017 12:11pm
Paul thornton
Picked this up for a friend (the porsche)
Post #454230 16th Oct 2017 7:46pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
front arm replaced and gearbox fluid and filter done , enjoying the silence
Post #454433 18th Oct 2017 5:03pm
gizze
Replaced the front drop links.
It wasn't really clunking as such, I just never felt it was as smooth as it could/should be over rough roads and tracks.
I had someone look at it and they said it was all fine, but I had my doubts.
Fitted the drop links and now it feels so much nicer, even over a really rutted track it soaks it all up beautifully. Porsche 911 (996)
Post #454435 18th Oct 2017 5:17pm
bembo449
we are similar people then Gizze , the slightest knock irritates the hell out of me pal
Post #454437 18th Oct 2017 5:36pm
deansmith
United Kingdom 2016 Range Rover Vogue SE SDV8 Carpathian Grey
Cleaned the MAP sensors today, although they were surprisingly clean already. Whilst I had the engine cover off I noticed another leakage from a the end of a hose. The hose clip seemed to be pretty loose so cleaned it up and nipped it tight. I’ll keep an eye on it.
Also lubed the lower tailgate springs to eliminate an annoying noise on opening and closing.
Post #454845 21st Oct 2017 8:03pm
