Home > Maintenance & Mods (L322) > Door lock paddle barrel.
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Trying to replace driver's door lock actuator. RAVE says disconnect door lock paddle barrel. It fails to say how to do it though. Anyone have a clue? The pic makes it look like it pulls out but it is hard to see or how it is connected.
Post #455095 24th Oct 2017 4:14am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi,
When you open the door you should be able to see a grommet on the door edge that is in line with the exterior door handle.
Take out the grommet and inside is a torx screw/bolt, unscrew it and the door lock / barrel can be pulled out. Take care on replacement as the ‘blades’ on the barrel rod need to be lined up with the actuator to enable the door to be unlocked using the key.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #455106 24th Oct 2017 9:13am
JCW
United Kingdom 2012 Range Rover Autobiography TDV8 Sumatra Black
If you mean the lock barrel itself, which has a sort of star shaped paddle on the end of a shaft that locates into the main lock unit, then it's just a case of removing a small screw thats located under a rubber grommet on the side of the door, about level with the door handle, then the lock barrel can simply be withdrawn.
Post #455107 24th Oct 2017 9:15am
JCW
...beat me to it!
Post #455108 24th Oct 2017 9:15am
UK Marine
Thumbs Up ______________________________
Simon
Post #455118 24th Oct 2017 10:08am
doclees
Thanks yes sounds like it. Now maybe I can find it in the RAVE.
Post #455134 24th Oct 2017 1:38pm
doclees
Nope. RAVE does not provide a picture of this. Just says do it like it is in our DNA. Maybe I can take some today.
Post #455139 24th Oct 2017 1:53pm
UK Marine
Have a look at this video from Powerfuluk.
03.08 is where you need to be....
Simon
Post #455144 24th Oct 2017 2:24pm
doclees
Oh hell yes now I get it. It's part of the key lock. So undoing the one torx and backing out the key lock from the outside removes the barrel paddle from the actuator. Now why could RAVE say that?
Post #455154 24th Oct 2017 3:31pm
doclees
Yay new door actuator in. Boo it looks like I need to go deeper. I pull the handle and nothing engages. I thought the new actuator was going to fix this too but I see in the video the cable end tends to break off.
Post #455222 25th Oct 2017 12:22am
doclees
Post #455223 25th Oct 2017 12:23am
