Home > For Sale & Wanted > [For Sale] 2010 10MY 3.6 TDV8 Vogue SE, 77k miles, FSH
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
its crossed my mind! Cheers
James
Post #433248 30th Mar 2017 6:11pm
wow thats a pile of problems for a 37k mile car!! DPF could be down to how it was driven before you got it.
mine used a bit of oil and there are places they leak, had a drip in the dipstick tube and a leak on the turbo feed, both fixed under warranty.
Check the orings where the turbo feeds come out of the back of the engine for weeps and the oil cooler in the V as you probably know.
apart from a couple of problems sorted under warranty mine has been pretty trouble free, certainly better than my 3.6, so its probably the luck of the draw!! Hope it gets sorted soon though.
In terms of running either car, if you dont do mega milage the 2010 should go on for another 5 years easily, so may the 4.4, you are basically dammed if you do and dammed if you dont!!!! There is nothing that can't be fixed with a hammer😜😜
Post #433255 30th Mar 2017 6:52pm
JST
4.4 is fixed now, it needed the oil drain mod to the turbo drain on B bank. was using approx 0.5L per 500miles
DPF was full from the build up of this burnt oil plus hole after the CAT but before the DPF giving false pressure readings and restricted performance issues.
supplying dealer (merc!) didnt respond to my requests for them to fix it either for 2 months! Oh the joys! Cheers
James
Post #433272 30th Mar 2017 8:26pm
That makes JLR sound good!! There is nothing that can't be fixed with a hammer😜😜
Post #433274 30th Mar 2017 8:44pm
JST
especially considering i had only had it 2 mths at that point! Cheers
James
Post #433278 30th Mar 2017 9:09pm
JST
3.6 still available, please note the comments above about problems relate to another vehicle! (the 4.4)
£19450ono Cheers
James
Post #458057 21st Nov 2017 12:16pm
