Home > In Car Electronics (L322) > Bluetooth upgrade.
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
Bluetooth upgrade.
I'm getting a bit of trouble with my bluetooth lately, call quality isn't what it was I think and it's becoming a little intermittent.
My iid tool says "fiber optic communication bus" so I've done the bypass on the bluetooth module to keep everything else running, no signs of any moisture down the back or anything so maybe the module is just coming to the end of it's days.
I'm aware of the part numbers in wiki for the modules but I'm just wondering, if I go searching for a newer replacement unit from a breakers etc., what's the best/easiest direct swap, plug and play unit that I can use from another vehicle.
I mean, if I go to my usual breaker, he lets me go down through the yard, what other cars and what years have the same module?
Discovery?
RR sport?
BMW X5, 5 series, etc?, although I think these are different.
Mine is a 2006 with the touch screen, obviously the fiber optic system since I've bypassed it.
I successfully flashed the unit a few months ago which solved the auto connect and phone book problem so not sure a reflash will do any good this time.
I haven't removed the module yet but like I say, a quick look in situ doesn't show any moisture present but perhaps removing it and sticking it somewhere warm for a while might help.
Many thanks in advance for any advice.... Thumbs Up
Here's the unit currently fitted...........
Post #456536 8th Nov 2017 2:49pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Disconnect it and see if there is any green on the pins. you may be lucky and be able to take it apart and clean it up, its very easy to take apart. I did it on mine when I was on holiday but mine was full of water so had no luck.
cheers and good luck Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #456543 8th Nov 2017 3:57pm
hamlet
Cheers Alex, thanks for that.
I actually did get a chance to remove the unit today and as soon as I had it out it was very apparent what the problem was, a little pool of water sitting between the unit and the mount.
Some green on some of the pins, stripped the unit, cleaned, dried, refitted and all working again.
Now just to find how it got wet, can't see any water anywhere else, everything is bone dry, bottom of the floor in the left compartment where the modules are, around the spare wheel, everywhere all dry, maybe some got in during a powerwash or something, guess I'll just keep and eye on it for a while.
Cheers.
Post #456717 9th Nov 2017 10:29pm
Lee Marsh
England 2006 Range Rover Vogue Td6 Zambezi Silver
As yours is a jaguar set up (touch screen head unit) might find that Jaguar may do a later Bluetooth device.
I’ve the same old Nokia in mine (2006 L322 Td6) hasn’t worked since I’ve had it.
I think it might come down to MOST fibre optic transfer rate which I think is 25 mbps on our
cars.
Difficult to determine which devices are cross compatible.
Does yours have the aux in?
Good luck
Post #457169 13th Nov 2017 8:40pm
Blair
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Also interested in the same question. Mine wasn't there, and had been bypassed when I bought it, so I'd like to know what breakers to look out for to get one!
Post #457231 14th Nov 2017 10:41am
hamlet
Thanks for the info Lee, I've actually managed to dry mine out and get it working again with no problems for the last week so fingers crossed it sorted, just have to keep and eye out for a leak somewhere.
I don't have the aux in on mine.
Cheers.
@Blair, I believe Wiggins is the man to talk to about this, he might be able to help you out although I'm not sure how active is is on the forum and more.
http://www.fullfatrr.com/forum/member-wiggins.html
http://www.bluetoothexchange.co.uk/
Post #457605 17th Nov 2017 2:44pm
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Very common issue the early Nokia Bluetooth module is crap disconnects and always needs re pairing to phone also signal quality and sound crap too. I had a leak very common which finished the module off anyway so I by passed it and a few months ago I bought a 2009 Range Rover sport Bluetooth module take a look on flea Bay many about ranging from £150 to £200 works great better sound clarity to. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #458148 21st Nov 2017 10:50pm
jaysta10k
Previous Cars
BMW M3 Carbon Black
Post #458150 21st Nov 2017 11:00pm
