Home > Duckworth Parts > Oil seal |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
Ouch, could be an expensive diff rebuild! I would drop the oil first and inspect it for water ingress (rusty sludge) We have found quite a few that have corroded the driveshaft/internal components (hence the seal failure) |
25th Jun 2014 9:20am |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 |
Seal TBX000110 would be £15.90inc vat You can paypal direct using - www.paypal.me/duckworthparts
25th Jun 2014 9:50am |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 785 |
Changed the oil in it about 6 weeks ago. Was surprised how clean it was. At the moment, just looks like a seal failure. |
25th Jun 2014 11:56am |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
I've got the same leak - how easy was the job?DO you need the press tool? Does the flange release easily with a tap? how hard is the lower arm to hub bolt to undo & redo? |
24th Nov 2017 10:16pm |
