Home > Maintenance & Mods (L322) > Chain guide and tappet question.... |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
You won’t see much with just the cam covers removed, the upper timing chain covers removed reveals a bit more but that’s a fair bit more work and the lifters are more work still as you are then getting into timing the engine.
29th Nov 2017 11:37pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
Definitely not vanos Rattle I have had this engine on two previous e39s which had this and had it prolifically on startup. This is not that this is a high pitch tick which comes from one bank and get faster and slower with rpm.
30th Nov 2017 7:40am |
Also - reading in here a good way to tell is to drop the oil pan and see if there is plastic in the pan - is this easy to do? Thanks Current stable:
30th Nov 2017 5:30pm |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
Yes dropping the oil pan is the easy way to check..
30th Nov 2017 5:45pm |
http://www.bimmerfest.com/forums/showthread.php?t=518173
30th Nov 2017 8:17pm |
Right feel this information needs to be out there... so as you have seen I and others were convinced I had a dead tappet... anyway after some googling on BMW forums last week to find a diy I stumbled across another solution someone said which I laughed at and didn’t feel needed repeating... until now when I thought I’d give it a go... apparently any plug except ngk have history of backing out of the m62 - this is exactly what had happened a loose plug (britpart brand?) so replaced with Bosch super 4s ( I know I said ngk are what to get but I bought these a while back so will keep an eye) and she’s quiet as a mouse so now that’s fixed and my startup rattle I just need to do my rocker covers Current stable:
3rd Dec 2017 7:56pm |
Good work, i have heard of that before and did check mine but mine were all tight but i am still thinking i may have an exhaust leak somewhere up front.. |
4th Dec 2017 7:42am |
