Home > Maintenance & Mods (L322) > egr fault codes |
mrtidy Member Since: 31 Aug 2015 Location: Stockport Posts: 211 |
Am I right in thinking that my egr valves need replacing ? 2009 Vogue SE Zermatt silver |
5th Dec 2017 3:02pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
A cheap alternative 1st option could be induction cleaner. It might clear the problem. Or it might be a waste of money. ______________________________
5th Dec 2017 11:18pm |
I've tryed induction cleaner as recommended by landrover indy. .so does look like replacement time. 2009 Vogue SE Zermatt silver |
5th Dec 2017 11:46pm |
The next alternative to replacement is removing and blanking the EGRs and fitting emulators.
6th Dec 2017 11:58am |
Not sure about emulators but it's now going into landranger services to have both egr valves replaced so fingers crossed all will be well, it will be interesting to see if my car drives any differently when it's done. 2009 Vogue SE Zermatt silver |
6th Dec 2017 4:13pm |
Just connected my iid tool and the egr 1 position is 7% and egr 2 position is 5%. And these figures don't move either up or down so unless I'm reading the figures wrong is looks like they may be both stuck. 2009 Vogue SE Zermatt silver |
6th Dec 2017 5:46pm |
Have you seen this post?
6th Dec 2017 11:36pm |
Thanks rar110.I have seen that post but as mine aren't working properly they will have to be removed so may as well put new ones in. 2009 Vogue SE Zermatt silver |
7th Dec 2017 12:07am |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
I could be wrong but the egr valves need to be closed as they can break up and "lunch" the engine.
7th Dec 2017 11:23pm |
Think I'm going to replace them with new ones and hopefully they will be fine for another 95000 miles. .not sure about blanking and remapping. 2009 Vogue SE Zermatt silver |
8th Dec 2017 8:14pm |
Well both egrs have been replaced cost £675 fitted Inc vat labour etc.i think that is a good price. All seems well now,all fault codes have gone and egrs are moving up and down in sequence with each other according to my iid tool.I think my engine may be slightly quieter now and the squeak squeak noise that I used to have for a few seconds after switching off has gone too,(I was under the impression that was the egr valves cleaning themselves ).so all is well fingers crossed. 2009 Vogue SE Zermatt silver |
17th Dec 2017 2:56pm |
