Home > Technical (L322) > Well that's not gone well |
babagee Member Since: 15 Feb 2015 Location: Somewhere between St. Helens & Kazakhstan Posts: 142 |
2009 Stornoway Grey Vogue TDV8 |
6th Dec 2017 11:11pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Plug it and get your codes read, you never know it might not be terminal, but then again..
7th Dec 2017 2:26am |
wack61 Member Since: 17 Nov 2017 Location: Cheshire Posts: 104 |
No waning lights on , revs right up to the red line, on tickover it doesn't sound too bad , thing is if you look on eBay there's dozens for sale but few sold listings so it could have stood with no oil in for years
7th Dec 2017 8:02am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3191 |
Sounds very much like the top end. Have you had the cam covers off to look at it? John
7th Dec 2017 9:39am |
I've used the mechanic that fitted it for over 10 years, he has a lot of experience with diesel engines, he's telling me because it's running on 6 cylinders and revs to the red line he thinks it's the little end because it's too loud to be a stuck tappet problem.
7th Dec 2017 1:13pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 285 |
Give money back for part is ok, but money for work? TDV8 4.4 from 2012, 278.000km like new + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
7th Dec 2017 6:35pm |
Money for labour , fat chance of that , at least he's holding his hands up over the engine. |
7th Dec 2017 7:05pm |
I found a M57 forum somewhere in Europe on faceache , they're telling me to get the injectors tested as it could be an injector problem , I've never heard an engine sound like that without it being something major causing it , could it knock that loudly from an injector issue |
9th Dec 2017 6:33pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
The only time I've ever herd anything like that was under extreme load on a very hot engine... so it could be an injector running weak... hopefully you still have 6 spares! Yesterday I couldn't spell Engineer... Today I are one!
9th Dec 2017 7:28pm |
Spares of everything, 2 complete engines, I think it needs further investigation before I spend £600 on another engine plus the same on fitting . |
9th Dec 2017 7:45pm |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 399 |
When the injector o rings went in my D2 TD5 it sounded very similar.
12th Dec 2017 11:12pm |
Picked another engine up today only I've seen this one running and I've bought it with the injectors still in it , decided it was going to be cheaper in the long run just to write it off and start again rather than try chasing faults down at £££ an hour |
13th Dec 2017 12:29am |
New engine fitted , got the call today, come and get it, running fine
19th Dec 2017 8:15pm |
The main thing is you're back on the road Yesterday I couldn't spell Engineer... Today I are one!
19th Dec 2017 9:32pm |
