Home > Maintenance & Mods (L322) > egr fault codes
mrtidy
United Kingdom 2009 Range Rover Vogue SE TDV8 Zermatt Silver
egr fault codes
The amber check engine light has popped up on my dash and I have the following codes. I take it I have a sticky egr valve?.
I remove the codes with my iid tool and they will stay away for a day or two then come back, I have no running issues just the codes any advice etc. before I take it in to be sorted out?
P0405-21(2E) exhaust gas recirculation sensor A-circuit low-general sgnal failure-signal ampiltude<minimum.
P1335-21(2C) exhaust gas recirculation position sensor minimum stop performance-General signal failure -signal amplitude<minimum.
thanks in advance. 2009 Vogue SE Zermatt silver
Post #459550 4th Dec 2017 1:57pm
mrtidy
Am I right in thinking that my egr valves need replacing ? 2009 Vogue SE Zermatt silver
Post #459678 5th Dec 2017 3:02pm
rar110
A cheap alternative 1st option could be induction cleaner. It might clear the problem. Or it might be a waste of money. ______________________________
Post #459766 5th Dec 2017 11:18pm
mrtidy
I've tryed induction cleaner as recommended by landrover indy. .so does look like replacement time. 2009 Vogue SE Zermatt silver
Post #459773 5th Dec 2017 11:46pm
rar110
The next alternative to replacement is removing and blanking the EGRs and fitting emulators.
I’ve had the EGRs unplugged for 18 mths with emulators. All ok so far. ______________________________
Post #459815 6th Dec 2017 11:58am
mrtidy
Not sure about emulators but it's now going into landranger services to have both egr valves replaced so fingers crossed all will be well, it will be interesting to see if my car drives any differently when it's done. 2009 Vogue SE Zermatt silver
Post #459828 6th Dec 2017 4:13pm
mrtidy
Just connected my iid tool and the egr 1 position is 7% and egr 2 position is 5%. And these figures don't move either up or down so unless I'm reading the figures wrong is looks like they may be both stuck. 2009 Vogue SE Zermatt silver
Post #459831 6th Dec 2017 5:46pm
rar110
Have you seen this post?
http://www.fullfatrr.com/forum/viewtopic.php?p=459837#459837
A remap and blanking plates is another good alternative to replacing EGRs. ______________________________
Post #459901 6th Dec 2017 11:36pm
mrtidy
Thanks rar110.I have seen that post but as mine aren't working properly they will have to be removed so may as well put new ones in. 2009 Vogue SE Zermatt silver
Post #459904 7th Dec 2017 12:07am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
I could be wrong but the egr valves need to be closed as they can break up and "lunch" the engine.
If it was mine I'd remove them, clean them and seal them closed. Re - fit them and then map them out with a re-map.
It would still be cheaper than 2 new egr valves as they are around £250 each.
Just my 2 penneth. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #459990 7th Dec 2017 11:23pm
mrtidy
Think I'm going to replace them with new ones and hopefully they will be fine for another 95000 miles. .not sure about blanking and remapping. 2009 Vogue SE Zermatt silver
Post #460073 8th Dec 2017 8:14pm
mrtidy
Well both egrs have been replaced cost £675 fitted Inc vat labour etc.i think that is a good price. All seems well now,all fault codes have gone and egrs are moving up and down in sequence with each other according to my iid tool.I think my engine may be slightly quieter now and the squeak squeak noise that I used to have for a few seconds after switching off has gone too,(I was under the impression that was the egr valves cleaning themselves ).so all is well fingers crossed. 2009 Vogue SE Zermatt silver
Post #461146 17th Dec 2017 2:56pm
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
