Home > Technical (L322) > My 2010 6hp26 improvements? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1688 |
I believe (but stand to be corrected) they fitted the 6HP28 |
8th Dec 2017 9:01am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34907 |
thats correct mikey
8th Dec 2017 10:24am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Did they have two different spec versions of the 6 speed in the same production year? ______________________________
8th Dec 2017 11:44am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 910 |
ZF upgraded the three versions of their 6HP transmission to ‘2nd generation’ models. All the model numbers increased by two i.e. the 19 went to 21, 26 to 28 & 32 to 34.
8th Dec 2017 11:47am |
Thanks Phil.
8th Dec 2017 11:56am |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 385 |
the 2010 diesel has the 6hp26 box doesn't it? __
8th Dec 2017 2:49pm |
I suspect you’re right J, and JLR has two different spec 6hp2#’s for the two different motors. ______________________________
9th Dec 2017 10:25pm |
I believe the mechanical parts are interchangeable, but the electronics are not. Pre/Post 2010MY have different CAN networks, and are not compatible, hence the need to swap the mechatronic unit over |
9th Dec 2017 11:54pm |
Yes, the plan is to eventually swap over the valve body but keep the old TCM. Apparently the TCM can be detached and swapped over from the valve body. ______________________________
10th Dec 2017 12:02am |
