Home > Maintenance & Mods (L322) > Passed her MOT, but told steering is 'heavy' |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34871 |
could be the servotronic valve, do a search and see if the symptoms are the same. ... - .- -.
18th Dec 2017 5:55pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1335 |
When it happened to my 2004 car the power steering motor was failing and needed to be replaced. Only Range Rovers since 1988 |
18th Dec 2017 5:57pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3035 |
It’s 99% likely to be your bcu (body control unit) under the passenger seat. Search for bcu on here and see a lovely talk thru by our colleague in France. I just replaced mine and instantly had perfect weighted steering again. Under an hour to do.
18th Dec 2017 6:21pm |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 452 |
Most kind, Dolphinboy
19th Dec 2017 11:15am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 757 |
You ever change the power steering fluid ? |
19th Dec 2017 7:39pm |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 719 |
cheers all
20th Dec 2017 5:00pm |
I changed my fluid a few months ago
21st Dec 2017 8:10am |
Cheers guys, interesting post Dolphinboy as a while ago I had 3 drains from fuses, 1 was the usual FSR (replaced that), the other was from the headlight wipers (pulled the fuse), and the 3rd drain was from the BCU fuse (cant remember the number, but theres a long post on here about it I started) She's going in for new brakes and fluid in the next couple of weeks, and to have power steering fluid replaced, so if that doesn't solve it I'll look a the BCU (and no doubt come back with lots of questions too) |
1st Jan 2018 4:16pm |
Have you seen the Ken_Curtis's £70 'BCU repair option' post:
1st Jan 2018 5:37pm |
Sharpy1980 Member Since: 20 Nov 2016 Location: Kent Posts: 55 |
Mine had heavy steering with no funny noises from the pump etc so I replaced the servotronic valve on the pas rack and it was an instant 200% improvement and it’s been perfect since and that was at least 12 months ago, the part was about £100 for a genuine part from a specialist and I changed it myself in about an hour and 1 of the 2 bolts was seized, probably the best £100 I’ve spent on the FF |
1st Jan 2018 5:54pm |
Just had a very quick read of bebechoon’s link to Ken_Curtis thread and my passenger side rear door doesn’t unlock either, the more I read the more it points towards the BCU I’ve got an iCarSoft code reader, will plug it in this weekend and see what codes/faults come up Cheers guys |
3rd Jan 2018 11:07pm |
Rose Member Since: 04 Jan 2018 Location: Portland Posts: 2 |
My RR was heavy in the steering it went onto susp inactive again and I had the faults cleared. Now the steering is back to normal. |
4th Jan 2018 3:26am |
Had the power steering fluid changed (hadnt been done since I got her, *cough* several *cough* years ago) but no improvement
15th Jan 2018 10:40am |
Sharpy1980, how hard is it to change please? Am guessing not too hard, but im not great with a set of spanners |
15th Jan 2018 10:42am |
