Home > Technical (L405) > Weak jets - windscreen wash |
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 |
mine are really good and deliver a powerful fine droplet which covers the whole screen, same for the head lights 2010 defender utility
28th Dec 2017 8:05am |
Thanks bear, they do work but the spray seems to hit just underneath the wipers and seems more like a mist as opposed to a strong jet. Maybe they need to be adjusted |
28th Dec 2017 8:30am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1340 |
Assuming your screen wash is concentrated enough not to be freezing, and the nozzle heating is not defective, the problem might be nozzles clogged with polish or other dirt. They can be cleaned out (and redirected) with something like a darning needle. Only Range Rovers since 1988 |
28th Dec 2017 1:51pm |
Thanks CS, the reservoirs are always full of concentrated screen wash so definitely not frozen.
28th Dec 2017 2:22pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16165 |
If you have a compressor, disconnect the rubber pipework under the bonnet and give them a good blast through |
28th Dec 2017 2:25pm |
I do have a compressor Craig. Wouldn't have thought of that one cheers |
28th Dec 2017 3:55pm |
29th Dec 2017 12:31am |
swissomatic Member Since: 16 Feb 2016 Location: Charleston SC Posts: 46 |
Interestingly I just had washer jets replaced under warranty as they were hitting the trailing edge of the bonnet. It was an improvement but not perfect. Only noticed while I was replacing wiper blades with Piaa Aero Vogue which incidentally are brilliant. |
30th Dec 2017 2:59pm |
