Home > Technical (L322) > 2012 4.4 TDV8 Engine Bay |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
You are correct , two air filters 2015 4.4 AB
12th Jan 2018 5:18pm |
Popeye Member Since: 15 Sep 2017 Location: Kent Posts: 27 |
Many thanks.... Bought some EGR cleaner that I sprayed into the intake pipe. Will have to get another one to do the other side now. Damn it!!! |
12th Jan 2018 5:23pm |
K8DJK Member Since: 08 Nov 2012 Location: Lincolnshire Posts: 10 |
I understood one was for the primary Turbo and one for the secondary?
12th Jan 2018 5:31pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
The rest of BB's picture shows the rear and the numbered parts confirm the RH intake is for the 'fixed vane turbo'. The LH cleaner does the 'variable vane turbo'.
12th Jan 2018 7:00pm |
Again my understanding, but the Primary is the variable vane turbo and the Secondary is the fixed vane turbo
12th Jan 2018 7:49pm |
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 |
Is the EGR valve cleaner spray any good? Seen the vids etc and what they show looks like it does the job. |
12th Jan 2018 8:10pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2301 |
The primary is on the RHS. The secondary filter will be much cleaner than the primary due to lower usage. |
12th Jan 2018 8:55pm |
I changed mine recently and the right ( drivers side) was quite dirty and the left was like new, im obviously not driving hard enough !!!!! 2015 4.4 AB
12th Jan 2018 9:16pm |
For reduced dust intake I've considered fitting a slightly modified D3/4 snorkel to the right side only as the secondary turbo on mine is rarely used. |
12th Jan 2018 10:31pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16165 |
UK drivers side is the main turbo the other/passenger side is the secondary turbo... |
12th Jan 2018 11:05pm |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 |
Anybody know if EGR spray cleaner is any good? If it is, is there a preferred make to go for? Thanks. |
13th Jan 2018 3:05am |
There is only 1 EGR valve on this engine so spray into the primary intake only. |
13th Jan 2018 4:19am |
I used the Wynns EGR Cleaner Spray. Noticed a little difference, not sure if it has fixed the EGR Valve yet as not had a chance to plug in the IID Tool yet. Will let you know. |
15th Jan 2018 1:07pm |
Thanks Popeye, interesting to see if it makes any difference. |
16th Jan 2018 2:08pm |
