Home > Technical (L322) > Rear screen heater wiring
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Can someone confirm that the two wires one black which is live (18v ?) and the red/yellow have separated . I suspect this is stopping the rear screen from de- misting .
Post #464410 13th Jan 2018 2:53pm
alfapat
Ok moving on , I have worked out that these two wires are separate.
The black wire seems to have separated from the base of the window from its soldered connection a nightmare especially with my soldering skills which are none .
Anyone had this problem , apart from getting a new rear screen!
Post #464431 13th Jan 2018 5:32pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
Not on a Range Rover, given I'm only just looking to buy one, but I had a very similar problem on my Defender a few months ago with the high level brake light, where one of the spade terminals for that, which is part of the window assembly, snapped off.
As long as there's some of the metal connection left on the window, you (or someone) should be able to solder the terminal back on. It was quite fiddly given the size of the parts remaining, not enough hands to hold everything and the fact for the brake light it was all above the head, but I did manage it. If you have a second person to hold the part in the right place, maybe with a pair of long nosed pliers or something, it might make it easier for you to concentrate on soldering a good joint.
I'd certainly give it a go (there's nothing to lose) and/or find a friend with some better soldering skills, before completely throwing the window away presumably incurring a reasonable cost.
Regards,
Paul
Post #464448 13th Jan 2018 8:01pm
alfapat
I need a course in soldering , never been good at it , welding .... no probs, I’ll get someone at work, plenty there. I can’t get the bare end to even take the tinning, it just falls off , maybe need some decent solder. The tab that is part of the window wiring is not helping and as you’ve said is above your head won’t tin either and you end up getting solder all over you , not good. Will try again tomorrow .
Post #464472 13th Jan 2018 10:38pm
alfapat
Partial success eventually , decent slider which had flux unit seemed to to the trick , not an easy job, I will see how long it lasts. Neutral
Post #464545 14th Jan 2018 5:45pm
paulbrown22
Excellent news. I'm no expert at soldering either, but mine has held on for a year now, which given how much a Defender shakes and rattles, I assume means it's good enough!
Post #464557 14th Jan 2018 6:43pm
alfapat
Good one Paul , well chuffed , first use this morning and snow and Ice falling off Surprised
Hey don't knof anyone has removed the trim around the frame inside the back window , its an absolute night mare to replace all the tabs were broken so its clinging on !
They seem to go for a reasonable price as well on ebay , but not my coulour , worst one is the wiper motor cover , this cold weather doesn't help when plastic is so brittle.
Post #464795 16th Jan 2018 8:06pm
paulbrown22
Wonderful - it's always nice when such a cheap fix works, especially after the soldering issues. You're well prepared for the next few days' weather now then!
Post #464840 17th Jan 2018 12:36am
