Home > Maintenance & Mods (L322) > Burning oil smell
Bluealpina
Burning oil smell
Help
Ive just driven up the side of a fairly steep mountain road in spain and when i got to the top my 10 plate 4.4tdv8 was smelling rather hot temp gauge was normal so i pulled over . Then the cabin started filling with smoke so i poped the bonnet and smoke was coming from the rear of the engine
Any ideas where to start please
Thanks
Paul
Post #465271 20th Jan 2018 5:55pm
Paul thornton
Sounds like the common oil cooler seals , or the pipe at the back of the engine leaking that Craig mentioned on here a while back.
Post #465274 20th Jan 2018 6:00pm
Baltic Blue
I agree with Paul.
Have you checked the oil level ?
If it has been leaking for a while you could have a build up on the plastic under tray which has run down on to the exhaust on the steep incline ? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #465276 20th Jan 2018 6:15pm
Bluealpina
Are they the ones that allow oil to mix in the water as ive just paid to have that job done before i left the uk
Cheers
Paul
Post #465277 20th Jan 2018 6:15pm
mjdronfield
It’s the oil cooler itself that cracks I believe. Just doing seals won’t be enough....the oil rings on the pipes that can also be an issue shouldn’t let that much oil out......
Your oil and coolant levels still good? No cream?
Could have been from when they did the repair with old oil still there? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #465280 20th Jan 2018 6:34pm
Bluealpina
Thanks
For all the info oil and water levels fine just drove the 1500 miles down and didnt miss a beat as you said i thnk it might just be the residual burning off
Soon find out as we are about to do the 1500 miles back soon
Post #465287 20th Jan 2018 7:11pm
If you have just had the cooler seals done then I would be looking at the 2 orings at the back of the engine. Easy fix for next to no money. Craig has a thread on it. The orings are readily available on the net and upgraded viton rings are recommended!
http://www.fullfatrr.com/forum/topic35977.html?highlight=o+rings There is nothing that can't be fixed with a hammer😜😜
Post #465290 20th Jan 2018 7:15pm
Bluealpina
Thanks will sort when i get back
Post #465316 20th Jan 2018 10:20pm
