Home > Maintenance & Mods (L405) > Changing wiper blades
Page 3 of 5 <12345>
RRVSE-2
United Kingdom 2017 Range Rover Vogue SE SDV8 Balmoral Blue
Have a look here http://www.fullfatrr.com/forum/topic45652.html , l have tried various on the L405 and find these are working well for me.
Keith Keith
Main car : FFRR L405 Vogue SE SDV8 Balmoral Blue
Main M/C : Ducati Multistrada 1200S
Other
Suzuki Jimny
Past Cars
Ford Fiesta Titanium
D4 Nara Bronze HSE
D3 Teal S
Post #466926 2nd Feb 2018 10:01am
stillnotpc
What Keith wrote works fine:
WIPERS SERVICE POSITION
Before changing a front wiper blade, the wiper
arms must be set in the �service� position as
follows;
Note: The Smart Key must remain in the
vehicle while wiper blades are replaced.
1. Ensure that the ignition is turned off.
2. Turn the ignition on then off again.
3. Immediately push the wiper control down
to start the single wipe operation and turn
on the ignition again. NOTE - while STILL HOLDING DOWN the wiper control.
The wipers will move to their service
position.
4. When the new parts have been fitted, turn
the ignition off. This will return the wipers
to park position.
I had the key in my pocket while I went round to the back to make the change, so it is not too picky.
Post #506468 26th Feb 2019 3:30pm
Andy B
+1 for the service position parking the rear blade in the middle. A real doddle. Just got some Bosch ones to replace the fronts. Any idea how you get the existing front ones off? They seem to be superglued to the arm! Confused SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #506489 26th Feb 2019 5:15pm
charlie croker mk2
These are a better alternative to the rather loud things that came on mine
https://www.ebay.co.uk/itm/Land-Rover-Rang...%7Ciid%3A1
Post #506499 26th Feb 2019 6:34pm
Mr Tee
Fitted an ar24u just before Christmas, started to not wipe in line of sight , basically where it clips in . Bought a new one just now , bloody identical , doesn’t wipe in the backstroke . Any and all ideas welcome. Fooking things .
Post #510083 28th Mar 2019 10:46am
awclymm
Just for reference, for the MY2017 onwards the blade fittings have changed to the quick release push button style.
The Bosch Aerotwin pack ( a 24" and a 20") for this model year is the Bosch A113S:
https://www.wiperblades.co.uk/bosch-a113s-aerotwin-wiper-blade
Or a single 24" that fits (with supplied adaptor) is the Bosch AP24U:
https://www.wiperblades.co.uk/aerotwin-plu...iper-blade
I have just ordered two of the AP24U's in the hope that I can still put 2 x 24's on the vehicle. I'll report back here if there's a problem with that approach.
By the way - I have had great service from www.wiperblades.co.uk (and I have no affiliation with them).
Cheers 2017 4.4 SDV8 Autobiography
Post #537188 12th Dec 2019 2:08pm
ilard
Interesting how thorough this Project Farm guy is. It’s my guilty pleasure.
 L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #537358 14th Dec 2019 12:10pm
For completeness, tThe older wiper fitting looks like this
If yours looks like there's a small square release tab, then it's the later fitting
Post #537381 14th Dec 2019 3:42pm
awclymm
Cheers
Yes, there is a problem with the approach I tried above - it desn't work - the supplied adaptors that come with the Bosch AP24U don't fit.
Looks like my only option is the Bosch A113S - which means that I am stuck with a 20" blade on the passenger side. 2017 4.4 SDV8 Autobiography
Post #537382 14th Dec 2019 3:46pm
Dave G
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
I tried to follow the instructions for the rear on my 2013 L405😩
But after trying to catch the wiper by opening the tailgate I decided in the end to remove the wiper blade complete with the arm.
Bit fiddly to reach the nut, but managed with a 13mm open ended spanner & a screwdriver to prise it off the spline.
Definitely easier in my opinion, hope that helps?
Blade was a Bosch H426 made especially for the L405
Dave G
Post #564813 17th Aug 2020 1:24pm
Mr Tee
I fitted mine when it was parked in it's resting position, was easy enough.
Post #564819 17th Aug 2020 2:37pm
the service mode works..... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #564821 17th Aug 2020 2:53pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
I can confirm that service mode works for MY2018+ too. The brake pedal doesn't have to be pressed.
So: with ignition off, press the Start button once and after it's on, once again to turn off. While pushing the wiper stalk down as to start the single wipe operation, turn on the ignition again. Both front and rear wipers will move to their service position. After servicing just turn the ignition off.
 2019 Vogue P400e
Post #564882 18th Aug 2020 10:40am
johnf
2013 Range Rover Autobiography 5.0 SC V8 Bonatti Grey
As mentioned above there are different front wiper blades depending on the MY. This is true of the rear also - although the size remains the same the connection to the wiper arm is different - as I learned to my cost when I ordered the wrong one recently. Rimmer Bros at least allows you to check against your VIN to make sure you order the right one. There are Bosch alternatives for both types too.
Post #564920 18th Aug 2020 5:13pm
adara
So, for MY2019 the correct replacement front wipers are Bosch Aerotwin A315S and the rear one is Valeo Silencio VR255. Ordered from https://www.autodoc.de/, the front ones costed £17.5 and the rear one £10... Shipping £8. Fun fact, the rear one is for Mercedes & Volkswagen vans!
Now, looking at the wipers that came with the car, I am convinced the rear one was a Valeo VR255, as it is identical to the new one.
The front ones are not Bosch, they look sleeker than the A315S, I don't know who makes them...
 2019 Vogue P400e
Post #569786 14th Oct 2020 8:41am
Page 3 of 5 <12345>
