Home > Technical (L322) > New MOT rules re DPF, should my aging TD6 be worried? |
wack61 Member Since: 17 Nov 2017 Location: Cheshire Posts: 104 |
Egr blank will if they check , TD6 hasn't got a dpf |
28th Jan 2018 11:47am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7625 |
Don’t think they can strip anything, so if you take the egr off and replace with the blanking kit they won’t see it..... 2011 Range Rover Vogue SE 4.4 TDV8
28th Jan 2018 3:04pm |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
No engine covers or undertrays are removed in an MOT. Your TD6 does not have a DPF either.
29th Jan 2018 11:12am |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 719 |
Thanks guys |
7th Feb 2018 6:44pm |
Just resurrecting this old posts guys, I read earlier about if any smoke it visable from the exhaust its a fail too on the new MOT, does this sound right?
6th Apr 2018 11:43am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
As far as I know the visible smoke point only applies to vehicles fitted with DPFs
6th Apr 2018 12:52pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1688 |
As above |
6th Apr 2018 1:31pm |
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 244 |
So when where dpf started appearing on ff's.
6th Apr 2018 8:50pm |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 183 |
In the UK, it was with the introduction of the 4.4 TdV8; it was optional on the 2010 3.6 version, but not many took it up. Regards,
7th Apr 2018 5:49am |
YEV1989 Member Since: 12 Nov 2018 Location: Yorkshire Posts: 1 |
My 2008 L322 3.6TDV8 has a DPF and I'm very much worried about the subjective visible smoke test. MOT due 22/12/2018.
21st Nov 2018 2:04pm |
