Home > Technical (L322) > 4.4 TDV8 oil change with electric pump |
dinosaurjuice Member Since: 11 Jan 2018 Location: Lancashire Posts: 19 |
Hi all,
9th Feb 2018 10:11am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
At main dealears prices for the job, your pump has already paid you back after only one change.
9th Feb 2018 12:38pm |
Ive got nothing against main dealers, i just prefer to do things myself. I really care about my cars, and take great pride in maintaining them. If it means buying/making a few special tools or equipment its just part of ownership! MY11 4.4 TDV8 Vogue SE |
9th Feb 2018 1:00pm |
I agree completely, and at least you have the peace of mind knowing that you have filled it with the right specification oil.
9th Feb 2018 1:08pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 761 |
Does anyone know where you can get the Castrol ? |
9th Feb 2018 7:14pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
That looks much easier than the big hand pump ones. What type of battery is that you are using to power it a motorbike one or something?? Current 2007 TDV8 Vogue Buckingham Blue |
9th Feb 2018 8:57pm |
The name of the Castrol oil has changed from what the handbook called it, yes.
11th Feb 2018 10:26am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
forget branding you've been brainwashed with marketing
11th Feb 2018 12:12pm |
carpcat Member Since: 13 Oct 2017 Location: Surrey Posts: 58 |
Castrol edge professional titanium FST C1 if you really want Castrol. Cheaper alternatives like Euro Car Parts Triple QX also do a C1 to the right spec. You’re best bet is looking on the Opie Oils website for a good selection. Just make sure it’s to the Ford WSS-M2C934-B spec if you’ve got the 4.4 TDV8. Chris |
11th Feb 2018 12:30pm |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 |
I've often been puzzled by this point. Some posts on here will advise "you must ONLY use this oil, nothing else will do!", but surely it's just a case of conforming to spec? If a fluid meets the manufacturer specification, who cares what brand it is? Especially true with bottles labelled "special Land Rover oil" costing £35 per litre, given that LR don't make oil in the first place! |
11th Feb 2018 1:05pm |
Oil company marketing plain and simple
11th Feb 2018 1:25pm |
You may have had all sense brainwashed out of you. speak for yourself
11th Feb 2018 11:33pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
You do know shell is cheaper 2015 4.4 AB
11th Feb 2018 11:46pm |
Its just a 12v battery from a little golf cart. Next time ill just use the vehicle battery, the leads will reach just about. I used oil meeting the correct spec (C1 and the relevant ford spec) from my local motor factors. 20 litres for £51+VAT. Will MY11 4.4 TDV8 Vogue SE |
12th Feb 2018 12:58pm |
