Home > Maintenance & Mods (L405) > 4.4 sdv8 remap? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3688 |
This might be a stupid question - but why? Surely it's quick enough at 6.5 secs to 60? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
13th Feb 2018 12:54am |
Nigt3 Member Since: 03 Dec 2017 Location: Belfast Posts: 35 |
You can never have too much Grunt! |
13th Feb 2018 9:47am |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 |
Flat out mine scares me ! Too big and too heavy. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
13th Feb 2018 11:12am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7751 |
13th Feb 2018 1:09pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1194 |
+1 _____________________________________________________ Zambezi silver Vogue Se unique |
13th Feb 2018 2:22pm |
Nelzuk Member Since: 06 Feb 2018 Location: Warrington Posts: 14 |
I am thinking about a DTUK Pedal Box controller. It just sharpens up the throttle response and it very simple to fit, had one on a 535d and it was quite good.
27th Feb 2018 10:14pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
I drove a customers 650 the other day with a DT peddle box controller and WOW!!!
27th Feb 2018 10:54pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2516 |
Throttle controllers seem a bit pointless - the only thing they actually do is mean you have to move your foot a little bit less for the same amount of progress, and you lose precision because more of the pedal travel is just pegged at maximum. |
27th Feb 2018 11:16pm |
I think you need to try one and decide for yourself , but in my last experience they do really make the car feel much more responsive and seem to reduce the lag. On a 535d I had the pedal box was a well worth addition,
28th Feb 2018 8:51am |
It is literally just a box increasing the rate of change of a voltage signal to the ECU (the accelerator is a potentiometer) - does not and cannot do anything but reduce the amount you need to flex your right foot. |
28th Feb 2018 9:31am |
Yeh I do get that |
28th Feb 2018 10:20am |
originalracingsnake Member Since: 14 Jul 2017 Location: Gloucestershire Posts: 19 |
That took me ages to read, and had all to do with the SDV8 tune! I wonder where the OP is now? He dropped off... 2014 SDV8 L405 Autobiography. Luxor with ivory. 22's... |
28th Feb 2018 10:56am |
So you could get the same effect by wearing shoes with a thicker sole. 2014 SDV8 L405 Autobiography. Luxor with ivory. 22's... |
28th Feb 2018 10:57am |
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 112 |
I had my 2012 (L322) 4.4SDV8 remapped in Australia; It gained around 46kw and 150nm of torque. I've had it for 6 six years and its done 115000kms' Its been fantastic. I added twin 3 inch mandrel bent exhaust at the time so it sounds sensational under load, but quiet as when cruising. I had the 8 speed auto fluid changed last week as preventative maintenance (I tow a 3.5tonne off road caravan) and it was in good condition (fluid).
1st Apr 2018 3:48am |
