Home > In Car Electronics (L322) > Problems with the sat nav, sometimes!
Tight777
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
Sometimes it works fine, other times no.
First it always has Belgium as the host country, I change it, its fine then I'm back in Belgium.
Sometimes I change from north up to direction and it freezes.
Sometimes it won't come off the "Don't use whilst driving or you'll die" screen, so I can't use it at all.
Are there any updates or later discs that may help?
Late 2007 spec.
Post #468326 12th Feb 2018 9:11pm
Pvw10
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Yes 2017 ones exist google is your friend.
The disc is only read, I had similar once and it wasn’t the disc sadly. Many thanks
Paul
Post #468456 13th Feb 2018 3:29pm
Tight777
Thanks wasn't sure if the later discs would work in an older system, I'll keep a look out.
I must admit I tend to use waze on my phone any.
Post #468466 13th Feb 2018 4:36pm
dingg1
mod edit, link deleted...
please do not link to illegal sat nav discs as this is against forum rules..
Post #468469 13th Feb 2018 4:58pm
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
