Home > Technical (L405) > Battery replacement |
wack61 Member Since: 17 Nov 2017 Location: Cheshire Posts: 104 |
I've bought many batteries from Tayna over the years, never had a problem with any of them
28th Dec 2017 11:06am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7736 |
No There’sobviously a physical size issue - it has to fit, but some batteries are way better than others - a bit like buying regular torch batteries - some last a lot longer than others..... If in doubt you could always get a battery from a main dealer - Dan will likely quote for one. There are also 2 batteries in the L405 |
28th Dec 2017 1:44pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16165 |
And remember yours is probably an AGM battery so, far more money then a regular LA battery...
28th Dec 2017 2:39pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Always bow to an experts opinion , that being said , can you tell me where you get the info re the LR battery being to a different standard to others branded and manufactured by the same manufacturer. Not looking for an argument just clarification. Friend of mine owns a starter motor / alternator company in Dublin and buys starters from a large German maunfacter and pays 25% premium to have buy branded as opposed to unbranded and he says they are the same but some customers insist on branded.
28th Dec 2017 2:57pm |
All I can say about batteries is from my own experience , I've had euroline batteries on the last few cars without a problem , I fitted one to a transit a couple of months ago , it's not been started for 2 weeks but fired up ok this morning in -2 temperatures.
28th Dec 2017 7:43pm |
Dolph it was just our experience sir... We have tried many many different type of batteries through the years and none can rival JLR batteries in later model 322’s & 405’s imho...
28th Dec 2017 8:43pm |
Experience is a great teacher and i was just interested if you had any insight that maybe the average joe ( me ) didnt have. Thank for the answer.
28th Dec 2017 9:03pm |
29th Dec 2017 12:28am |
IansL405SDV8Autobiography Member Since: 18 Feb 2018 Location: Bedworth Posts: 5 |
Hi all, I’m new to this site as this is my first RR although I’ve had many Landrovers over the years. Having experienced electrical/battery issues I wanted to share what I’ve learnt as a now ex technician. Not to brag my RR Autobiography 2014. 30,000 miles has every conceivable electrical extra on it along with dash cams & as I do very few miles have suffered on numerous occasions of it only just starting ! LR Assist have been out more times than I’ve had hot dinners & every time day my battery is ok. They repeatedly say the cause is the pre heat which I’ve set up to come on twice a day is the problem as it’s opperatin when the alternator isn’t putting any charge back into the battery. Obviously makes sense but I find it extremely poor of JLR to put a standard battery on my vehicle with so much electrical requirements so I looked into this Problem. I found a Varta H15 which although longer will fit into the battery tray under the suspension air pump. It’s 393mm long which is about 20mm longer than the factory fitted battery. Most importantly it’s 105ah & 950cca which are significantly bigger than the standard ! I’ve had no issues with the car since this change. I did read many saying RR’scwith all the bells & whistles had two batteries but this is incorrect. For UK spec RR’s only stop start models have a small secondary battery or if it’s an import/export for cold countries like Russia LR do fit a secondary battery for cranking requirements. I hope this information helps as I suspect unless you cover thirty minutes or more driving x twice a day there will be many others like me needing guidance. Ian |
18th Feb 2018 11:31am |
You should have 2 batteries - photos on this thread might help.
18th Feb 2018 6:11pm |
Hi Alistair & thanks for the reply. I was told by LR assist I only had one battery as I don’t have stop start (thank god !) but if you think I have two I’ll get the o/s side panel off tomorrow & have a look. I don’t suppose the original boot floor battery would be the same size etc as I’ve just updated that with a Varta H15, larger in length but it fits perfectly in the battery tray but has better ah & cranking umf ! To answer the climate conditions, no I live in the midlands but I love getting into a warm RR ! It’s the best gadget at this time of the year. Hopefully the stronger battery will correct LR’s cost saving original, time will tell. Ian |
18th Feb 2018 8:30pm |
