Home > Technical (L405) > L405 FBH Telestart Receiver Fob Pairing - Solved |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7751 |
Isn't there a fuse you can pull ?
19th Feb 2018 6:37pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 837 |
Thats a very good point! off to investigate... |
19th Feb 2018 6:57pm |
PLOG Member Since: 19 Nov 2018 Location: Teesside Posts: 22 |
Did this work, JCW?
5th Dec 2018 5:52am |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 |
All working. Pulled the fuse for the FBH and then upon re-insertion held the off button down on the fob, and it's all paired again.
5th Dec 2018 8:38am |
Could you confirm which fuse no. you pulled Charles?
5th Dec 2018 11:42am |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
so glad it worked.
6th Dec 2018 12:20pm |
I received my remote today and removed the panel in the boot to reveal the same view as in Alistair's picture above. However, I can't see any fuse numbers... I can see two fuse boxes - the large one just under the ivory trim in the pic, and a smaller one that's behind a cut out in the sound insulation just below the bright yellow connectors in the pic.
12th Dec 2018 3:47am |
Its the yellow 20a fuse at the bottom left hand side of the smaller fuse panel, slightly hidden by insulation.
12th Dec 2018 9:12am |
Thanks, JCW. I did find the diagram an hour or three later when I was putting it back together!
12th Dec 2018 9:38am |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 198 |
I assume it does have a remote reciever unit and ariel fitted ? |
12th Dec 2018 7:36pm |
The build sheet says “Park heat with remote”, so I would assume so. At least that’s what I’ve read on here. I can’t imagine anyone would have removed the receiver, but it seems pretty common that remotes aren’t passed on when vehicles change hands.
12th Dec 2018 7:41pm |
reciever I would of thought be in the rear o/s panel as per the picture
12th Dec 2018 7:54pm |
ive just taken delivery of my L405 and no remote climate , but I took the remote and reciever off my 11my RRS hopeing that it would fit a L405
12th Dec 2018 7:58pm |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 769 |
Now the InControl App doesn’t operate the Park Heat, only starts the RR, I want to add a second fob to leave at work. A couple of questions:
15th Dec 2018 2:22pm |
