Home > Maintenance & Mods (L322) > FBH disabled?
Andyyav
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
FBH disabled?
I didn’t think I had a FBH as there wasn’t a remote with car, no valve on the bulkhead and timed climate isn’t an option on the screen.....then after i spotted the exhaust while investigating coolant / heating issues I took the inner wing off while doing lower / upper arms and found this
So.....has it been disabled? Can I enable it again? Any fuses etc I should check??
Post #469002 17th Feb 2018 2:28pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Do you have an IID tool? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #469005 17th Feb 2018 3:23pm
Andyyav
Unfortunately not, I’ve had the codes read before and it’s never been mentioned, can the tool turn it off without registering an error?
Post #469011 17th Feb 2018 3:42pm
dolph34
It proberbly not turned off but the screen controls can be activated by the tool. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #469012 17th Feb 2018 3:44pm
dolph34
My 07s FBH worked if the car was running ( it cut in once
engine was started) but i had no control over it until I enabled it with the iid tool and then the screen controls became active, i didnt have the remote control unit ( receiver)in the boot so i bought one second had and fitted it with an aerial. The power and control cables are already prefitted. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #469014 17th Feb 2018 3:52pm
Sandyt
From memory the diesels all have one and they cut in when the temp is below 12 or 13 deg c to help the engine get up to temp quicker whether they are all turned on so that they can be manually used dont know - Think that is why the bulk head valve is not there The valve stopes the engine being warmed up so that the interior can be
Post #469054 17th Feb 2018 7:21pm
Andyyav
Appreciate all the reply’s some great info!
So the FBH maybe working without any control from me, Would/could this affect the heating in the cabin eg the drivers side is well behind the rest of the car on heating up,I figured this would be down to the control valve mounted on the wing I thought this was a two valve control sending to the drivers / passengers side maybe It’s sent via the FBH to the drivers side? is there any way to check my set up with out the tool?.......lots to investigate and explore I think!!
Post #469096 17th Feb 2018 9:53pm
Sandyt
The two valves on the side are restricted flow one for each side and they work on the return not the feed again it is a while since I did all this and mine is a petrol but the cooling system is nearly identical
Post #469109 17th Feb 2018 10:39pm
Sandyt
My guess is that the drivers side is not opening fully if you take the engine cover off and the pollen filter box off you can access all the pipes and feel which is getting warm and which is not
Post #469111 17th Feb 2018 10:41pm
Rich_Allen
Where abouts in Norfolk are you? 2008 TDV8 Vogue SE
2002 TD6 Vogue
2002 Defender 90 TD5
2002 Range Rover P38 Autobiography
2002 Range Rover P38 Westminster
Just a sucker for big bills!!!
Post #469180 18th Feb 2018 5:01pm
Andyyav
About 30 mins east of Norwich, you?
Post #469264 18th Feb 2018 11:24pm
Rich_Allen
I’m over in Stamford, but come down to burnham market every now and again as my mum lives over there...
If you were near I would be happy to plug my IID up and activate it for you... 2008 TDV8 Vogue SE
2002 TD6 Vogue
Post #469269 19th Feb 2018 12:16am
Andyyav
A very kind offer, I’m thinking of investing in one myself as I’ve a ‘lumpy’ idle issue.......
Post #469513 20th Feb 2018 11:00pm
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
the lumpy issue will probably be an faulty injector mine was you can get them repaired as replaced saving you ££
Post #471025 4th Mar 2018 7:45pm
Andyyav
Would a faulty injector throw up a code?
The last time I had lumpy idle was after I ‘cleaned’ the MAF and MAP sensors, I’ve replaced these and all appears well
Post #471027 4th Mar 2018 7:52pm
