Home > Technical (L405) > Central diff engages at cold start |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2303 |
The diff being reported as locking indicates that the electronics are instigating the locking, so the cause wont be related to oil viscosity. |
26th Feb 2018 8:23pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1340 |
Could this be a feature of Terrain response 2, i.e. does it still do that if you select 'normal drive' manually? I recall reading that in colder weather TR2 automatically selects 'grass gravel snow'. Only Range Rovers since 1988 |
26th Feb 2018 9:42pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3688 |
+1 mine is in manual mode permanently - I noticed the lock-up when pulling out of junctions on full lock or with a wet road surface. Manual mode cured it. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
26th Feb 2018 9:49pm |
Gruute Member Since: 05 Jul 2012 Location: Flanders Posts: 136 |
I have the automatical terrain response. I will try to go on manual mode to avoid it.
28th Feb 2018 8:44pm |
Central diff is blocking when fresh started during the first kilometers. Every corner the car is grabbing on the axles when I touch the trottle. even gently. This is not normal.
5th Mar 2018 10:35pm |
Neil183 Member Since: 21 Dec 2016 Location: Rickmansworth Posts: 31 |
I have exactly the same with my car. It has an extended warranty and they will supposedly be looking at it, but initial response is that it's a known issue, resolved by changing they diff oil twice apparently?! |
6th Mar 2018 2:03pm |
Range Rover went to dealer for the problem.
7th Aug 2018 3:38pm |
