Home > Maintenance & Mods (L405) > L405 Rear brake pad replacement 2014 model |
Mariana Black Member Since: 30 Jul 2014 Location: Stockton-on-Tees Posts: 89 |
Managed
30th Sep 2017 8:17pm |
Steve j Member Since: 22 Feb 2018 Location: Pontefract Posts: 6 |
You say you bought a wind back tool, I believe these do twist in the plunger as it goes back, not just push them back?
22nd Feb 2018 10:54pm |
RRVSE-2 Member Since: 06 Jun 2015 Location: Kent Posts: 41 |
Had this recently on my 14my, the piston also has 3 pins for the wind back toll to lock into when pushing it back - fairly rare apparently. Laser do a tool with 3 adapters and adjustable pins which l have...... now !! Model 6329. Other than that all quite straight forward.
23rd Feb 2018 10:28am |
Hi
25th Feb 2018 8:43pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16163 |
As has been mentioned above the car MUST be put into maintenance mode or you will have a VERY EXPENSIVE rear calliper replacement for your troubles |
26th Feb 2018 12:33am |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
so how is it put in maintenance mode then ? |
26th Feb 2018 11:47pm |
Via a diagnostic machine sir... |
26th Feb 2018 11:49pm |
Can the IID tool from Gap do that then ? - I have one of those. |
2nd Mar 2018 11:02am |
Yes sir it can... |
2nd Mar 2018 11:29am |
johnf Member Since: 16 Nov 2012 Location: Nottinghamshire Posts: 84 |
I'm about to do mine so have looked into the service mode. I've discovered that this can be accessed without a diagnostic machine as follows:
25th Oct 2018 6:57pm |
Does anyone else iid tool give error E7 when using it to try and set the rear brakes into maintenance mode? |
27th Feb 2019 11:48pm |
Hi
28th Feb 2019 9:49pm |
28th Feb 2019 9:58pm |
Did my rear brake pads and discs today.
11th Mar 2019 8:21pm |
