Home > Maintenance & Mods (L322) > Torx socket sizes?
GGDR
Torx socket sizes?
Hi Team,
I've got some (male) torx drivers for the various (female) torx screws around the car but need to unbolt my seat and realised I need some - I guess you'd call them female torx sockets - for the male torx bolts.
What kind of sizes will I need generally on the car?
There's a set with: TORX SOCKETS:E4,E5,E6,E7,E8
Will this do or are there more/other sizes I need?
Thanks in advance.
Greg Cheers, Greg
Post #470299 27th Feb 2018 9:55pm
Clive603
England 2004 Range Rover HSE Td6 Orkney Grey
I bought a US Pro branded 17 piece impact set covering E5 to E24 for under £25 last year.
Seemed a good bang for buck ratio in and a half decent box too. Savings on smaller or less well packaged sets didn't seem objectively worth it. Getting just the tools I need now never seems to work out for me.
Compared to 40 years back when I first started spannering tools of perfectly acceptable quality are dirt cheap in objective terms today.
Clive
Post #470316 27th Feb 2018 11:51pm
bishbosh10
When you say Torx bolts, are they 12 pointed bolt heads rather than torx? If so, a normal socket (12 pointed obviously!) will fit.
Not had a look at my seat bolts to check, sorry. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #470392 28th Feb 2018 3:47pm
GGDR
These are the sockets I think I need (but not sure about sizes)
I'll take a picture of the seat bolt - I thought at a glance it was 6 pointed. Didn't think to try a normal socket...
Greg Cheers, Greg
Post #470401 28th Feb 2018 4:45pm
kbald
A 12 sided socket might welll do the trick if you have some to try. Failing that you can get female torx socket sets with most sizes on amazon for a few £'s normally going up to e24. Current 2007 TDV8 Vogue Buckingham Blue
Post #470406 28th Feb 2018 6:08pm
GGDR
This is the seat bolt.
Are these bolts used elsewhere around the car?
. Cheers, Greg
Post #470605 1st Mar 2018 8:12pm
GGDR
I ordered a set of torx sockets.
In the meantime I tried a standard socket. Which fits perfectly. Rolling Eyes
10mm for the seat bolts if anyone needs to know.
. Cheers, Greg
Post #470982 4th Mar 2018 4:37pm
yep a standard socket will fit, but you wont be able to put the same torque through the bolt as a E socket.
I have a cheap set of Forged Steel ones from Screfix should I need to undo any in the future, came with some splined head keys as well. There is nothing that can't be fixed with a hammer😜😜
Post #471010 4th Mar 2018 7:02pm
