Home > Maintenance & Mods (L322) > 4.4 TDV8 Intake |
headless21 Member Since: 28 Jun 2016 Location: Yorkshire Posts: 23 |
I have just cleaned my intake out it was full of oily carbon deposits. The clip in your picture is on a fork bracket, just carefully pull it towards the front of the vehicle and it will slide out of the bracket. Just be careful and you should be fine. Current Range Rover Vogue SE 2011 4.4 TDV8
10th Mar 2018 6:51pm |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 |
Thanks Headless. Cant get the thing to budge. I thought maybe it had to be uncoupled and got myself a nice coolant shower. 2011 RR Autobiography 4.4 TDV8 |
10th Mar 2018 6:53pm |
No mine was stiff, but I definitely just pulled towards front of car. Like I say it's on a fork bracket. 👍 Current Range Rover Vogue SE 2011 4.4 TDV8
10th Mar 2018 6:55pm |
Just thought another odd thing is the 2 plastic posts that hold engine cover on. I used pliers near bottom of post to unscrew plastic top (as they looked like they would snap using a screwdriver) then a small torx socket to remove small bolt that plastic top is screwed onto. You may have already done this. I was fixing oil cooler leak. Current Range Rover Vogue SE 2011 4.4 TDV8
10th Mar 2018 7:12pm |
Thats what in trying to get too, and the oil pipe that goes into it to replace the o-rings. Didn't realise they need to come out.
10th Mar 2018 7:27pm |
If you are only doing the pipe with the 2 o rings then you can access it from the back of the engine without removing anything apart from pollen filter housing 2x 13mm nuts. Then using a mirror you can undo the bolt holding pipe in. Replacing o rings took about 20 mins. I tried that 1st before I realised oil was coming from between oil cooler and top of engine so had to remove air intake to remove oil cooler to replace the gasket. That took 3hrs approx including cleaning air intake which was in a terrible state with carbon build up.
10th Mar 2018 8:24pm |
Im doing the gaskets on the oil cooler too. Not sure if they are leaking or if its just residual oil from the turbo pipe. Stinks inside when I come to a standstill. Cars done 85,000 miles so if they haven't failed i'll do it as a preventative measure to save stripping it down again. Will give it a good clean out while its apart. 2011 RR Autobiography 4.4 TDV8 |
10th Mar 2018 8:52pm |
I see, mine is a 2011 and done 82k so your probably wise to do all at once. If you have any problems or questions just give me a shout I will be glad to help.
10th Mar 2018 9:04pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Speaking of dirty air intake systems, has any one tried a spray cleaning system - here's one
10th Mar 2018 9:53pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
The mechanic has used Revive on my car a few times. The 1st application at about 230,000km made a noticible difference. I now have a maintenance dose done about every 20,000km. ______________________________
11th Mar 2018 12:42am |
the stud that one of the plastic engine cover mounts onto has no head on it. Any suggestions on how to remove it? 2011 RR Autobiography 4.4 TDV8 |
11th Mar 2018 10:26am |
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 32 |
I have started a thread on induction carbon cleaning as like you, I noted the build up af tar.
11th Mar 2018 10:45am |
