Home > Maintenance & Mods (L322) > Foam rubber blocks at rear of bonnet |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 |
Mine have disintegrated too. I guess they are part of the sound insulation. If the parts low cost it makes sense to replace them. |
11th Mar 2018 6:26pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34913 |
they come in two parts per side, called insulators...
11th Mar 2018 6:51pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2516 |
Replaced twice under warranty, third ones have now disintegrated. They soak up water badly. |
11th Mar 2018 7:50pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
They are a water trap and can cause corrosion! They are also behind the bumpers and in the chassis recesses! All ready to rot the panels out in years to come! |
11th Mar 2018 7:58pm |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 183 |
Many thanks Stan. |
11th Mar 2018 8:36pm |
So, would you be comfortable taking them off and not replacing them on your car Craig? |
11th Mar 2018 8:49pm |
I have Ryan... |
12th Mar 2018 1:46am |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 |
I find the ones on my car soak up water really well! Sorry, couldn't resist, IKWYM. Anyway, they are a poor piece of design, and if Craig says they aren't needed, that'll do for me. If anyone can specify exactly where else they appear on the car (L322 in my case) that would be most helpful. |
12th Mar 2018 10:09am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4225 |
Mine were in a state and soaking. Removed. Time will tell if I need to replace them 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
17th Jun 2019 8:26pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 895 |
Likewise, mine are falling apart and although I have the replacements, I can't see the point in fitting them if they'll just do the same again.
18th Jun 2019 10:25am |
its when they crack that the water soaks in...my new replacements stayed dry..[until they get old and crack again] ... - .- -.
18th Jun 2019 10:31am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
I have tried standing them in the sunshine ( last summer not this ) to dry them out which helped, then I sprayed them with a good coating of WD40, but next time they get very wet they are going in the bin.
18th Jun 2019 10:59am |
First run on A3/M27 without them today and I could not hear any difference.
18th Jun 2019 12:06pm |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
I want to replace mine but am slightly confused about the fact they come in 2 parts?
20th Aug 2019 3:06pm |
