Home > In Car Electronics (L322) > No TV image |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34871 |
move FF to a different location?
13th Mar 2018 5:52pm |
Beemergriff Member Since: 06 May 2016 Location: Northamptonshire Posts: 62 |
Thanks Stan. I have tried in 3 different locations, with no noticeable change in results.
13th Mar 2018 6:07pm |
there are two signal amps underneath the windows in the cubby boxes, maybe one of them is faulty..
13th Mar 2018 7:02pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 350 |
Antenna amplifiers as Stan points out are already fitted in the rear load space side compartments . One of mine seemed to have a snapped connection though when I bought the vehicle, so I had to repair that. My whole tuner unit then turned out to be dud, so I swapped it out with a cheap Ebay job, and it then sprang into life. Worth checking all the connections are correctly fitted, clean, etc. - if you don't have RSE, is very easy to remove the tuner/connections for inspection.
13th Mar 2018 9:15pm |
Thanks for the advice, and I will start by checking that all the connections in boot funny holes are good
14th Mar 2018 2:05am |
