Home > Maintenance & Mods (L322) > Temperature Gauge Intermittent |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 508 |
Hello all. I'm a former D3 owner and now owner of a 2009 3.6 TDV8. Very pleased with it so far bar a few bits of tidying needed here and there.
13th Mar 2018 7:20pm |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 216 |
Worth noting that a faulty oil temperature sensor can cause the coolant temperature gauge to go abit mad. |
13th Mar 2018 7:36pm |
Interesting thanks. So is checking live values my best first step in that case? |
13th Mar 2018 9:13pm |
Did an oil change last week and intended to change the oil temperature sensor but discovered that it needs a 30mm deep socket. Closest I had was 32mm. So completed the (very messy) oil change and ordered a new socket.
1st Apr 2018 7:25am |
Fingers crossed it sorts the issue out. |
1st Apr 2018 10:29am |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 685 |
My gauge did exactly that! Then I had a new oil sensor temp sensor fitted! Gauge now works as it should 2007 VOGUE SE 3.6 TDV8 |
1st Apr 2018 11:24pm |
Good news - it seems to have cured it. Thanks for all the help. 2016 Skoda Octavia VRS Estate
4th Apr 2018 4:01pm |
