Home > Maintenance & Mods (L322) > TD6 - to blank off EGR or remove and clean? |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
Get rid |
15th Apr 2016 11:39am |
rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185 |
Is there a link to another post to show how to remove or clean? Would like to give it a go but or at least see if its something i could turn my had too. |
25th Apr 2016 2:49pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
No body bothers to clean a TD6 EGR, you can get a new bypass for under £30... by the time you've brought the cleaner and faffed about....is it really worth it?
25th Apr 2016 3:43pm |
FYI if you haven't already downloaded "2002-2006 workshop 'REPAIR' manual RAVE" in wiki, DO IT! it will tell you everything you need to know about taking bits off of ffrr's....... if your lucky you can sometimes find the instructions to reassemble Yesterday I couldn't spell Engineer... Today I are one!
25th Apr 2016 3:50pm |
cheers miggit, going to have a look at the guide, will use the search option to track it down
25th Apr 2016 3:55pm |
Wiki is at the top right hand corner of every fullfatrr.com forum page
25th Apr 2016 4:41pm |
Yeah....well......i knew that. |
25th Apr 2016 5:19pm |
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 73 |
To convince yourself that it will be worthwhile do a comparison test.
5th May 2016 1:17am |
N11roadwarrior Member Since: 12 Jun 2016 Location: Wicklow Posts: 2 |
Hello all, which EGR blanking kit would you recommend ? |
13th Jun 2016 8:56pm |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 719 |
Thought I'd resurrect this old post guys, after a house move and other time consuming things I've now got more time to spend on the old girl (the FF, not the missus )
23rd Mar 2018 5:01am |
Hi all
29th Sep 2018 2:14pm |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 218 |
Egr removed on my td6 by somebody ( ) with fan and shroud on unless you know where to look difficult to see not there, past mot first rev couple weeks ago. |
30th Sep 2018 1:17am |
Miggit, Ive downloaded your link and unzipped it But cant seme to open anything now its unzipped? Am looking for a 'run.exe' type option, but cant find anything?? what am i doing wrong please? |
30th Sep 2018 10:08am |
mark35gun Member Since: 01 Oct 2018 Location: swanwick Posts: 63 |
been disconnected on mine for 9 years and about 60000 miles, no ill effects, just pulled off the pipe and blocked it, maybe should have done more but i diddnt and its ok to date (touch wood) 2011 4.4 tdv8 autobiography black
26th Oct 2018 7:02pm |
