Home > Maintenance & Mods (L322) > Oil filler cap hard to remove |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Is it under pressure? You may have a blocked breather. It should never be that tight it bends a tool. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
22nd Mar 2018 7:18pm |
petewild Member Since: 14 Mar 2013 Location: Croydon, Surrey Posts: 45 |
Hi Grofus,
22nd Mar 2018 7:58pm |
A blocked breather will cause oil leaks and make the cap hard remove. Its why bottles of fizzy drink have the relief channels in the neck. Same thing applies here.
22nd Mar 2018 8:06pm |
Top fella
22nd Mar 2018 8:10pm |
posted it twice somehow!!!!! 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Mine has always been a bit of a b@gger to undo, usually resort to the plumber's wrench to loosen off. fortunately never use any oil so only have it off at service time .
22nd Mar 2018 10:32pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
I use water pump pliers on full opening. Can't use my hands as they are old a full of pain. Vent is clear and neck is smeared with oil on refit but still sticks. |
23rd Mar 2018 5:19pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
at least if it's tight it won't come off and spurt oil every where... ... - .- -.
23rd Mar 2018 5:38pm |
^^^^^ said the actress to the bishop!! .
23rd Mar 2018 5:54pm |
23rd Mar 2018 6:48pm |
The winners for the best suggestion goes to Joe and Clive, just tried the water pump pliers and worked a treat, thanks !
23rd Mar 2018 7:53pm |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 |
Mine is a pain too and there isn't any space for leverage. I had a small rubber strap wrench that worked. It broke so I need another one. |
23rd Mar 2018 8:59pm |
