Home > Technical (L405) > Burning Rubber Smell |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34911 |
touch the wheel after the long journey and see if the wheel is hot..it could be a sticking caliper.. ... - .- -.
28th Mar 2018 12:41pm |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 890 |
Burning rubber?....those were the days!!! |
28th Mar 2018 2:46pm |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2152 |
Yes, I’ve had it on mine too. I did check all the calipers straight away and they were all cool. I’ve had the same thing on at least one of my late D4’s. It never seems to have caused a problem.
28th Mar 2018 9:20pm |
Edgey808 Member Since: 17 Apr 2016 Location: U.K. Posts: 48 |
Hi All,
9th Dec 2020 6:44pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 735 |
I think the DPF regen sounds like a plausible explanation. Kev
9th Dec 2020 9:48pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16169 |
Or a leaking engine oil cooler? They leek onto the exhaust and STINK!!! Worth a check |
10th Dec 2020 1:07am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4220 |
Leaky oil cooler was my first thoughts...get underneath and see if any oil on rear edge of engine under tray first. 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
10th Dec 2020 9:36am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 442 |
Agree with Dr Rob and Craig, done quite a few of these and they do stink a bit. |
10th Dec 2020 10:05am |
Thanks all I will have a look to see if there are any leaks? |
10th Dec 2020 11:02am |
Only had a quick look this morning, I’ll have more time at the weekend.
10th Dec 2020 3:06pm |
Ok so after further investigation, I have a very small leak from the oil cooler gasket 😖 (as you predicted.) currently ordering the recommended seals / gaskets as per other the other threads on the subject.
17th Dec 2020 11:07am |
