[Free] Rear light cluster (damaged) | |
I have a rear right hand light cluster from my 2010 L322.
The outer clear plastic is broken and much of it missing. Part of the grey plastic, some of which is hidden when fitted, is also broken. The lights themselves were working when I replaced the cluster about a year ago. It’s been sitting in the garage since, so every reason to believe that it’s still working. If you like, I can plug it into my car and check.
If this is of use to anyone you’re welcome to it. If no-one wants it, I will chuck it out next weekend.
You’re welcome to collect from me if you’re nearby. Home is Corsham, Wiltshire; work is central Bristol (very near Temple Meads Station).
If you’re not nearby I will send it by courier but I’d be grateful if you’d pay the cost of sending it. Should be about £8 to most places in the UK.
Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
